Aluminum Undereave Vent Residue - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2013, 11:17 AM   #1
Aluminum undereave vent residue
I installed multiple aluminum Air Vent 16"x4" vents over my 2" soffit holes about 6 months ago. I recently noticed an odd residue which I thought was bird poop, but upon closer inspection appears to be some type of oxidation or salt buildup. I do live in a tropical and humid setting, and was slightly concerned that this could be indicative of a bigger problem. Anyone experience or seen this before?
Aluminum undereave vent residue-img_2428.jpg   Aluminum undereave vent residue-img_2421.jpg   Aluminum undereave vent residue-img_2424.jpg   Aluminum undereave vent residue-img_2425.jpg
bee-man is offline   Reply With Quote
Old 05-08-2013, 04:20 PM   #2
Rewards Points: 744
wtf...how did you even see that? It's probably dust. If you're really concerned, poke your head up in the attic.
Seattle2k is offline   Reply With Quote
Old 05-08-2013, 05:20 PM   #3
Rewards Points: 14,312
Ok we give up. Please go back and add your location to your profile.
Just go to Quick links and add it.
Old 05-08-2013, 05:40 PM   #4
Roofmaster
Rewards Points: 2,210
Why didnt you cut open the whole area under the grille? The holes are choking off your airflow to zip.
Old 05-08-2013, 05:51 PM   #5
Metal Roofing
Rewards Points: 600
+1 i would have cut it larger.
Please paint them white
Is it oily to the touch ?
AndyWRS is offline   Reply With Quote
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 02:45 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Moving Return Vent Upstairs Rowhousefix HVAC 0 08-11-2010 02:39 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
