Aluminum Siding Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-20-2014, 12:53 PM   #1
Hello,
I own a house bulit in the 1960's and it has it's original aluminum siding. Parts are missing due to storms. I was wondering if there was a place to order replacements or a solution to cover the exposed area so I can paint my house?
Thanks for your time!
WJTED2014
WJTED2014 is offline   Reply With Quote
Old 02-20-2014, 12:57 PM   #2
Rewards Points: 13,750
Need a picture? Why's anyone going to know what parts it is you need or how to fix it?
Old 02-20-2014, 01:11 PM   #3
Siding
Hello,
Sorry..it was just a general question to see if anyone knew of a website to custom order "filler pieces". I will take a picture tonight and post.
Thank You,
WJTED2014
Old 02-20-2014, 02:51 PM   #4
No such thing as "filler pieces".
Siding, outside corners, soffit?
No way would I be ordering aluminum siding and having it shipped.
Any real siding supply company in your area should be able to help.
If it's pieces of siding that needs replacing your in for a treat. You can not just remove a piece in the middle of a wall. Have to start at the top and remove it until you get to the bad pieces.
In most cases the top piece gets destroyed trying to get it out and will need to be replaced.
Old 02-22-2014, 12:18 PM   #5
Rewards Points: 144
Had a friend that wanted to paint his aluminum sided house but had some damage.This insulated al siding was all over here in the 60's.Since he wanted to repair and paint we looked around town for someone tearing off and residing that had the same stuff.Gave the crew a few bucks to take off what we needed in tact and used that.We pressure washed to bare aluminum,used a quality primer and paint suited for the application and it still looks pretty good 15 years later.
As far as replacing ,Joe has it right.No filler pieces.
There is one older lumber yard in town that still stocks the corners since they always blow off.
mako1 is offline   Reply With Quote
Tags
siding
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 03:34 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 04:02 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
