Aluminum Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-14-2014, 10:13 AM   #1
Aluminum Siding
I have a need for 8" wood grain aluminum siding. Color doesn't matter. Just need about 8', and a corner post piece. I have made many phone calls, and have searched online, with no results. If anyone out there has a resource for this I would greatly appreciate it! I live in Springfield, Va.. That's Northern Virginia for those who live near by, and might have what I am looking for.
Thanks so much,
Gerry
canfieldgerry is offline   Reply With Quote
Old 08-14-2014, 11:12 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 898
Gerry,
I have on found smooth before but let me check.
Old 08-14-2014, 11:37 AM   #3
Rewards Points: 898
Gerry,
Called my 2 suppliers and smooth is all I can find.
Old 08-14-2014, 12:30 PM   #4
Thank you, hoping to find the wood grain if possible.
Old 08-14-2014, 03:28 PM   #5
Rewards Points: 392
Ran into the same problem on my house, I don't think the grained siding is available, unless you can come across some used.
rustyjames is offline   Reply With Quote
Old 08-14-2014, 04:23 PM   #6
Rewards Points: 12,868
What is it your really trying to do with these pieces?
I'm picturing your trying to replace a damaged corner.
How you going to replace it without removing all the siding?
Checked with Lancing Building Products, Eastern Aluminum Supply, ABC Supply?
There's just not much call for aluminum siding for the past 20 years or so.
If you Google Alcoa Siding they may be able to help you locate a dealer.
roofermann (08-14-2014)
Installing Full Frame Window - Existing Aluminum Siding walked Windows and Doors 7 03-20-2014 02:51 PM
Painting aluminum siding cherry_560sel Painting 27 04-25-2011 02:35 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
