Aluminum Patio Enclosure Roof Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-18-2010, 07:13 PM   #1
The roof on my patio enclosure leaks when there is heavy rain. How do I prevent/repair the problem on an aluminum roof with seams?
baileyd is offline   Reply With Quote
Old 01-18-2010, 07:58 PM   #2
Hard to tell with such little info.Pics may help a little
johnk is offline   Reply With Quote
Old 01-22-2010, 11:11 PM   #3
water test it....
water test the roof with a garden hose...find out where it is leaking and caulk...it really is that simple...
hammer71h is offline   Reply With Quote
Old 01-24-2010, 01:14 AM   #4
Thanks for the info. I'll try it!
Old 03-25-2012, 06:55 PM   #5
My aluminum patio leaks too. I know where the leak is coming from. Should I calk the leak from inside the patio or from the top outside?
Scorpio91744 is offline   Reply With Quote
Old 03-25-2012, 07:16 PM   #6
DIY staff
Rewards Points: 7,174
Caulking from the outside would be best.
Roofmaster417 (03-25-2012)
Old 03-25-2012, 10:05 PM   #7
Metal Roofing
Rewards Points: 600
It may be as simple as properly placed caulking, but without pics we are all just guessing. I see a number of patio leaks in CA and most of them are from a poor tie in. It is either tied into the fascia below the pitched roof incorrectly or tied into the roof incorrectly. Caulling it may be a temp bandaid if your having leaking in more than just a spot.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
Tom Struble (03-25-2012)
anchoring aluminum railing through EPDM roof? jbluth Roofing/Siding 1 09-12-2009 05:34 PM
Flat Roof Leak (used as patio above living area) brutter Roofing/Siding 4 04-13-2008 09:11 PM
large leaking tar flat roof erbilliards Roofing/Siding 2 03-16-2008 11:59 AM
Tar and Gravel roof leaking heehaa Roofing/Siding 4 12-11-2007 09:23 PM
Leaking roof -recommend a roof coating? Faust Roofing/Siding 5 07-12-2007 10:09 PM
