Aluminum Flashing Showing Through Shingles On New Bay Window Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-23-2013, 05:00 PM   #1
Aluminum flashing showing through shingles on new bay window roof
Hi,
I just had a new roof put on over my bay window. I just noticed the aluminum flashing is showing through between the top molding, and the upper shingles, on the left side. It might have been there since day 1 and I didn't notice, or it may have begun sometime after the roof went on. In the pic the spots I'm talking about are in the upper left of the roof, 2 gray areas about 6 inches long and one inch wide, going up at a 45 degree angle, between the top molding and the shingles. Why is this happening and how can the roofers fix it?
Kronor is offline   Reply With Quote
Old 08-23-2013, 05:51 PM   #2
Rewards Points: 13,300
Going to need a better picture.
Looks like the step flashing from little I can see.
Looks like it was installed to low in relationship to the shingle. None of it should be showing.
http://www.bing.com/images/search?q=...lectedIndex=32
Old 08-24-2013, 03:30 PM   #3
Thanks! What do the roofers need to do to fix it? How long will it take? If they don't fix it, will it leak or cause problems later other than cosmetic?
Old 08-24-2013, 03:36 PM   #4
Without a better picture it's anyone's guess what's wrong and how to fix it.
Old 09-02-2013, 01:50 PM   #5
Dallas Roofing's Avatar
Originally Posted by Kronor View Post
Hi,
Can not tell without better photos, but quick glace nothing is wrong.
There is a flashing going over the top of the shingles and up the wall. There is a counter-flashing going into the brick and coming down over the top of the flashing.
I think you are likely seeing the bottom of a galvanized flashing that is mostly covered by a painted counter-flashing. The galvanized portion really sticks out to the eye, but if this is the case it is a minor cosmetic issue.
Dallas Roofing is offline   Reply With Quote
Bulge in roof shingles and valley flashing daluu Roofing/Siding 4 08-07-2012 01:51 PM
Spacing of architectual shingles on hip roof nil8r Roofing/Siding 4 05-27-2012 12:12 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Epoxy roof sealant over shingles? P550 Roofing/Siding 15 04-11-2009 11:00 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
