Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-27-2010, 09:24 AM   #1
Aluminum facsia
Question............when I had my new roof installed and also had them put on aluminum sofits and facsia.........I notice that when the sun light shines directly on the aluminum, it looks bowed, bented and dented, I dont' see this under conditions only in direct sun. Is this normal? or was it installed incorrectly, thanks, G
turbomangt is offline   Reply With Quote
Old 05-27-2010, 09:28 AM   #2
Aluminum facsia
i hate residential metal trim for those reasons
The older I get the better I was
Old 05-27-2010, 09:30 AM   #3
Aluminum facsia
Is theri a difference between commercial and res metal, I would think metal is metal, no?
Old 05-27-2010, 09:37 AM   #4
Aluminum facsia
commercial comes in diff thickness/grades, if your lucky on res you may get a stiff coil stock but usually just thin aluminum which moves a lot from temp,poor fastening, direct sun ,poor sub structure. so yes it will move, of course you should'nt need to paint
Old 06-02-2010, 09:49 AM   #5
Aluminum facsia
Looks like spam found their way in here
Old 06-02-2010, 03:08 PM   #6
Super Moderator
Aluminum facsia
The effect you are describing is called, "Oilcanning", which is the distortion of the sheet metal, either aluminum, galvanized steel or even copper.
Darker colors show this more prominently, as does thinner guages of sheet metals used, which are very typical for residential usage, unfortunately.
Additionally, the fastening pattern and techniques may not have be adequately followed, thereby nailing the fascia metal instead of hanging or pinning the metal.
You are rarely going to encounter any installer, getting paid by production, who will either know or take the additional time or expense to do this trim metal precisely correct, so unless the distortion is so prominent to devalue the exterior aesthetics of your home on a regular basis, the best thing is to stop focusing on it.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
How to disassemble aluminum clad wood window sash? JohnBinSC General Discussion 6 01-17-2011 06:59 AM
Aluminum Wire Indoors NOTREALSURE Electrical 5 09-24-2010 05:39 PM
Capping windows with aluminum VS flashing with aluminum scott j Remodeling 28 04-05-2010 12:19 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
