The After-roof Roof Project - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-15-2011, 03:49 PM   #31
Rewards Points: 978
also you can see that the ductwork is actually part of the conditioned space under the decking.
federer is offline   Reply With Quote
Old 05-23-2011, 04:02 PM   #32
Rewards Points: 978
So running into a new issue-I took a look up into the ceiling and realized that both bathrooms have exhaust fans that are not connected to any ducts going outside! Has anyone have any experience with installing duct from fan to outside through the wall? Is this DIY friendly?
I assume I just need to connect the duct to the fan, then use a hole saw to drill hole through exterior wall. Then connect duct to the hole and cap it on the outside?
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
