Advice on separating two roofs
Hi
I need some advice on a re-roofing project.
The problem is I have two roofs connected by shingles and I would like to separate them.
Not sure if this helps at all, but here's the history: The house was built with a porch on the front (the lower roof on the front) that was later enclosed and made into a kitchen. Then, a stand-alone garage was built next to the house. Finally, the house and garage were joined with a breeseway.
Both the garage roof and the hip roof in the front need to be replaced, but at this point in time, I can only replace the front hip roof.
As you can hopefully see from the pictures, the two roofs are joined and if I am going to replace just one, I need to separate them, but I have no good ideas on how to do this.
Picture 2 shows the join, which is about 5' wide.
I hope I've explained this clearly.
Can anyone help with this?
Thanks . . . Brian
