Advice Needed On Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-17-2011, 09:14 AM   #16
Ahhh! TY!
You guys have saved my back side BIG TIME!!!. I had a roofing contractor say that they were going to use 1 1/2" - 2" roofing nails for the ridge vent project. Luckily, we haven't signed any paperwork or handed over any $ yet. I know from reading around this site that 2 1/2" is the minimum that should be used, if not longer.
We are going with the ridge vent now and may get the hip vents later.
Thanks for answering my Q's and preventing me from getting hosed.....again. (That was a different project....)
Brian
acdriverd15 is offline   Reply With Quote
Old 03-17-2011, 06:03 PM   #17
old timer
see you,
Dennis -
Did you test further? 10 degrees warmer/colder? Wind 5mph faster? Any sort of comparison in the same attic?
What would you suggest to get the air moving in that scenario? Or in the OP's scenario?
My house is similar to the OP's and I know the results of what I did to it. I'm a firm believer in air sealing and insulating VS trying to cool the inside of a house by fooling with the roof. But we need to keep the moisture out.
I was not able do more testing in different conditions.
I did make a video demonstrating the air flow after installing a power fan in the hip end.
Pretty much dispels any rumors concerning power fans pulling air from ridge vents.
So what is up with the 1/300 that I have see on some of the ventilation product packaging? Is it an old standard? Is it a government standard?
Actually that is an old standard. From the 1940's if I recall.
Last edited by Gary in WA; 03-18-2011 at 07:09 PM. Reason: Participants may not post any message that directs others to any pages at their own commercial web site, including informatio
dmc@RCR is offline   Reply With Quote
Attic insulation advice syogod Remodeling 4 12-09-2010 06:59 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Attic ventilation rchrst01 Building & Construction 2 11-16-2009 04:50 AM
Attic Ventilation Help Falchion14 Roofing/Siding 6 06-04-2009 01:22 PM
attic ventilation lou1968 Roofing/Siding 5 05-31-2009 09:33 PM
