Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-26-2008, 03:44 PM   #1
Advice on installing gutters on slanted fascia
I need to install gutters on my house to alleviate potential foundation problems and am looking for some advice. The fascia on my house is slanted--it is perpendicular to the roof instead of the ground. I'm pretty sure that it would be a less-than-ideal thing for me to install gutters flush to the fascia, because it would enable a lot of water from our Dallas downpours to flow over the gutter.
Are there some sort of special brackets that I need to use in installation to level out the gutters? If so, where would I find them? And if I have the gutters installed, will the typical installer know what to do?
Thanks!
PS - I got a quote from Guttermaxx earlier this week and was amazed that they charge close to $30 per foot for their gutters (including downspouts, installation, etc.), which would make the gutter job on my house add up to almost $6000.
notfromaroundhere is offline   Reply With Quote
Old 12-26-2008, 10:00 PM   #2
Super Moderator
You need to use a Gutter Wedge.
Here are 2 types available on this site.
http://www.guttersupply.com/p-wedges.gstml?s=gaw&kw=[gutter+wedge]
And this site offers them with diagrams for installation according to the pitch of the roof.
http://www.gutterworks.com/endcaps.html
http://shop.gutterworks.com/home.php?cat=17
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 12-27-2008, 04:36 PM   #3
Ed
I knew there had to be an "easy way".... Are these typically carried locally, or do they need to be purchased online?
Thanks!
Old 12-27-2008, 05:34 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks!
You should be able to obtain them from your gutter supplier. We do not purchase gutters from the Big Box stores. We buy them from a local gutter supplier. Do a search for a local company.
Gutter suppliers can deliver seamless gutter sections, in a variety of colors, along with gutter wedges, and all the other parts needed.
- Build Well -
Tags
fascia, guttermaxx, gutters
Need advice installing outdoor lights billyg Electrical 3 06-10-2008 08:43 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing 10 02-11-2008 08:34 PM
I need advice on installing self-adhesive floor tiles SavReb Flooring 2 11-20-2007 10:09 PM
Installing Gutters tate16t Roofing 3 09-29-2007 06:18 PM
fascia? gutters? johnny331 Building & Construction 9 06-19-2007 04:13 PM
