Adequate Ventilation For Roof????? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-04-2007, 10:54 PM   #1
Adequate ventilation for roof?????
I am a home inspector in So. Oklahoma and noticed a house roof today that does not have any venting near the ridge. It is about 6:12 pitch and mostly hip with two stagered gables projecting at a 90 degree angle from the main ridge which is higher than the gables. The gables cover the garage and have one louver vent on the lower gable. There are about 25 or so soffit vents. The question; Is there code requirements for proper ventilation? There are no ridge vents, turbines gravity vents or powered ventilators. It seems that on a plane equal to the height of the gable louver and above, there is no way for hot air to vent. Is this OK or in violation of some code?
thehousedetective is offline   Reply With Quote
Old 01-05-2007, 04:01 PM   #2
Just soffit vents will not let the roof breathe. Need to have intake air and exhaust air.
redline is offline   Reply With Quote
Old 01-18-2007, 02:34 PM   #3
Chief Fungus Fighter
Agreed. Having soffit vents without any exhaust at the top is a recipe for trouble and one of my best souces of business (see my user name).
There has to be an active flow of air thru the attic. If the home is in an are without much airflow or surrounded by trees, I recommend installing active ventilation fans as well as passive. They should be on a thermostat/humidistat control.
MoldBuster is offline   Reply With Quote
Honeywell Y8150 Whole House Ventilation system carquote HVAC 16 03-05-2009 01:06 PM
Bad House ventilation ????? kourso HVAC 1 07-11-2007 08:26 PM
Roof/Attic Ventilation pramos67 Roofing/Siding 6 03-30-2007 12:27 PM
Proper Attic Ventilation kmhill35 Roofing/Siding 2 04-01-2005 08:11 PM
