Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-02-2009, 02:19 PM   #1
HVAC Eng
Default Addition and Roof Replacement
Hi:
I'm new to this chat room so please bear with me.
I've attached a picture of my house with a thirty year old addition to house a dining room. I plan to move the side wall out to the edge of the roof line (approx. 5 feet) to make the dining room larger, and then put a three-season room off the back by extending the shed roof (obviously at the same pitch). I will need to set down the three-season room floor level by 7" to accomplish this.
The existing shed roof has a roll roof system, about two years old. I thought about simply extending the roll roof and lifting the lower edge of the existing to roof to lap over the top of the new.
I don't have any leaking of the existing roof, but I'm concerned about the possibility of the new seam leaking and about ice-daming, particularily with the unheated three-season room at the low level of the roof.
The roof pitch is about 1.5:12 and is flashed in under the 3-tab shingle of the steeper pitch roof.
Would I be wise to redo the entire shed roof instead of trying to splice in the new? Would a membrane roof be a better solution for this project? Is there a reasonably priced product for a residential application such as this?
Thanks for any suggestions.
HVAC Eng
lebeld is offline   Reply With Quote
Old 01-04-2009, 06:59 PM   #2
Originally Posted by lebeld View Post
Hi:
HVAC Eng
So what you are going to do is enclose what appears to be a covered porch now, then add a 3 season room to that? do you have Ice/water shield on existing roof? I would keep the 2 seperate, but use metal flashing & ice & water shield on both surfaces. The down fall to low pitch roofs ,are even roll roofing doesn't last many years.
butlersprints is offline   Reply With Quote
Old 01-04-2009, 07:33 PM   #3
HVAC Eng
I think you understand my situation properly, and yes, there is ice and water shield beneath the existing roll roofing.
What I think you are suggesting is to install metal flashing beneath the lower edge of the existing roll roofing and flash over the new roll roofing on the lower roof.
I agree that roll roofing has a short life, that is why I wonder if I should strip the existing roof and do the new and old with a membrane roof, or another type?
David
Old 01-04-2009, 07:54 PM   #4
David
Well the tricky thing is to flash properly from one to the other, you need to get metal UNDER the existing ice/water shield. Very difficult to lift already stuck ice guard. If you don't do it that way you will never get results you need. any other roofers have any imput? your metal flashing will be in the shape of a "Z". Under top layer of ice guard, down face board, out over lower level shingles, tar & nail down. with low pitch you will always have threat of build up. I would personally evaluate your needs to see if you want to have the burdan. perhaps contiue building in the direction you are extending would give you better results. Just a thought .
Old 01-04-2009, 08:11 PM   #5
Residential Roofer
Slyfox's Avatar
Being that the existing roof is newer and problem free you could use the same materials on the new section and so long as you take the new materials under the existing with out damaging the existing you'll be ok.
Should you decide to use a better system that will give you a longer life span than yes you should remove the existing and do the entire roof.
There are several systems that will work well on that type of roof.
Check out ABC Supply .
God Fearing, Husband/Father, US American, Pool Shooting Roofer
Slyfox is offline   Reply With Quote
More On This Topic
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
In this clip, I'm going to show you how to cut your graham crackers to create the graham cracker house. As I said earlier, we need fourteen full crackers to create this house. The lengths of the house are going to be two full crackers, as well as the... Read More »
In part two of assembling the house, I'm gonna show you how to attach the roof. I have re-loaded my bag to make sure I have enough icing, and we're going to put lots of glue around all these edges. This part can be a little tricky. It almost helps to... Read More »
Now we are going to discuss how to get up to the roof just in case to make sure that you are being safe enough to get up on the roof. Here I have a ladder right about 30 degrees of a pitch going up to the roof. It is study, both of the bottoms of the... Read More »
That shed or garage in your backyard may have more uses than just storing tools or that old car that hasn't run in three years. With some work and design skills, it could be converted into an extra residence to use as either a guest house for visitors or... Read More »
porch addition roof dhag Building & Construction 1 07-21-2008 07:16 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 08:56 AM
Considering Room Addition & Roof Change pkthomas_ar Building & Construction 4 05-02-2007 08:41 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 08:17 AM
second floor addition without removing original roof coralhead1 Building & Construction 8 10-06-2006 07:56 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
