Adding A Roof Over A Patio - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-08-2010, 03:45 PM   #1
Adding a roof over a patio
Newbie here, my wife and I are looking to put a roof over our big patio. We would be connecting the new roof to our exsisting roof off of our house.
Question is, what is the wood called where you can put a shingles on it and the nails don't show through on the bottom, which makes the ceiling look nice? I saw this on the lakehouse episode on Indoors Out.
etully24 is offline   Reply With Quote
Old 06-08-2010, 03:59 PM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Thick.
All kidding aside, I'm not familiar with any one product that solves this problem. Typically a finished ceiling board would be installed first, fastened to the ceiling joists/rafters and then another layer of plywood/OSB would be installed over that to give enough thickness so the nails don't penetrate.
seeyou is offline   Reply With Quote
Old 06-08-2010, 04:50 PM   #3
Are you reffering to an Open Beam Celing.
Ron Smith Const is offline   Reply With Quote
Old 06-08-2010, 08:35 PM   #4
Yes, I just looked at the pics of open beam and that is kind of what we are wanting, but I won't need the big beams. How thick does the wood need to be so that the nails don't show? A contracter suggested he would do a rubber roof but I don't know anything about them, are they cheap or expensive?
Old 06-08-2010, 08:51 PM   #5
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Yes, I just looked at the pics of open beam and that is what we are wanting. How thick does the wood need to be so that the nails don't show? A contracter suggested he would do a rubber roof but I don't know anything about them, are they cheap or expensive?
Rubber (probably EPDM) would be fully adhered, so there wouldn't be any nails except to fasten the metal edging around the perimeter.
Depending on the rafter layout, it might be possible to hit the rafters when nailing/screwing the drip edge which would eliminate the need for a 2nd layer of sheathing.
Old 06-08-2010, 08:58 PM   #6
Thanks for the info, Go Big Blue!
Attached Patio Overhead Roof Gandalf Building & Construction 8 04-19-2010 12:53 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
Flat Roof Leak (used as patio above living area) brutter Roofing/Siding 4 04-13-2008 10:11 PM
