Adding A Ridge-vent To My 12x16' Shed - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-22-2011, 04:18 PM   #1
adding a ridge-vent to my 12x16' shed
I'm considering adding a ridge-vent to my 12x16' shed this summer when I re-shingle/paper its roof. There are soffits on two sides. Is this something that's too complicated for its value? What should I be considering while I look at doing this project?
BoxAlarm is offline   Reply With Quote
Old 04-22-2011, 04:20 PM   #2
Some pics...
Forgot to add the first time around...
Also,
What are the "blocks" and bracing I see along the interior? What's their purpose? Thanks!
adding a ridge-vent to my 12x16' shed-img_1960.jpg   adding a ridge-vent to my 12x16' shed-img_1964.jpg
Old 04-23-2011, 08:48 AM   #3
Rewards Points: 5,336
It's a fairly simple project with your roof line. With the roofing removed, you'll cut the OSB back an inch or so on each side of the ridge. You'll roof up to the newly cut opening and then install the ridge vent and the cap shingles.
If you don't fall off the roof or cut yourself with the saw, you should be fine.
The blocking is to reinforce two boards that come together. The rafter ties keep the walls from spreading.
Ron
Old 04-23-2011, 03:16 PM   #4
Maybe I'm just not understanding your humor?
If you cut fall off the roof or cut yourself with the saw, you shld be fine
Cm1384 is offline   Reply With Quote
Old 04-23-2011, 04:01 PM   #5
I edited the post. It looked like someone having a stroke was posting.
If you're careful up on the roof you should be fine.
Ron
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 04:47 PM
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 04:06 PM
Ridge vent or not. Speedball Roofing/Siding 7 06-25-2009 09:02 PM
ridge vent ?'s Zel1 Roofing/Siding 6 05-19-2009 09:53 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
