Adding A Layer Of High Density Foam To Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-19-2008, 12:55 PM   #1
Adding a layer of high density foam to roof
I currently live in MN and have a older 1 1/2 story remodeled farm house. The upstairs has knee walls in about 8 ft from the side and stand about 4 ft inside from there to just about the peak of the roof it is 2x4 with 3 1/2" of fiberglass insulation. My roof seldom has snow (lots of propane).
I need to reroof and I have been considering tearing off the shingles and laying a layer of 2" high density foam over the existing plywood with a new layer of 1/2 plywood on top of that and then new shingles.
My question is has nayone done this and are the results worth the effort?
Thanks,
Mike Ehman
northen mn (-15 this morning)
gilltee is offline   Reply With Quote
Old 02-19-2008, 11:48 PM   #2
Try reading through this other recent thread and see if the concept of the ventilated insulation that I suggested is in alignment with your current thought process.
Ed
Ed the Roofer is offline   Reply With Quote
Adding insulation to a low-slope roof cbeingessner Roofing/Siding 25 09-21-2010 11:01 AM
Adding downspout to torchdown roof Grebus Roofing/Siding 8 10-07-2007 09:50 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
Adding a gable porch to a pitch roof fjacky Building & Construction 5 08-09-2005 06:56 PM
