Adding A Gable Roof..to An Existing Deck - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-17-2012, 11:53 PM   #1
helloitsme21's Avatar
adding a gable roof..to an existing deck
we had a contactor build a deck. he put 4x4 post as support under the deck.. however he cut them off at the floor.. he has now added 4x4 post using metal connector to sit on the deck to support a gable roof which seems very shakey... is this safe or should the be in the ground?
helloitsme21 is offline   Reply With Quote
Old 07-18-2012, 12:28 AM   #2
Rewards Points: 12,802
Post a picture. I see no way that's ever going to work out.
If he knew there was going to be a roof before he started building that would change the whole game plan. He should have used 6 X 6's not 4 X 4's for one thing, and ran them from the piers to where it attached to the roof system.
Most local codes now call for 6 X 6's for anything above a ground level deck.
mae-ling (07-18-2012)
Old 07-18-2012, 08:55 AM   #3
robertcdf's Avatar
It really depends upon the hardware and attachment method, however the building inspector should have to inspect the connection and approve it to move on. What do the blueprints that were submitted with the permit call for?
robertcdf is offline   Reply With Quote
Old 07-18-2012, 11:02 PM   #4
we fired him this morning... we live in a area where permits aren't needed. the hardware was a piece of metal that is to attach a 4x4 to a flat surface but he was attaching 12ft post that way to put a gable roof attached to the house
Old 07-18-2012, 11:14 PM   #5
Those posts would need to be minimum of 6x6 and down to a footing. Also you should get a permit just so someone can look over a print and sign off saying it would be adequate for the structure you are trying to erect. How are you securing the rafters to the house? Does the roof need collar ties. Do you live in an area where wind and storms factor the amount of tie down hardware should be used. These are all questions you should asking yourself. The permit is there to help you, ya know. You might not have to be here asking these question if you had a print and permit. Just saying
JoeCanning is offline   Reply With Quote
Old 07-19-2012, 02:02 AM   #6
well that's why we hired a professional however it can't be safe if I can wiggle it with my bare hands and it feels like its unsafe... there is always a chance of storms and wind but he spent 3 part days building a deck and hand rails for step. we paid him a total of 1000 dollars for a deck that ain't finished... and no banisters... keep in mind this deck was only a 8 by 10. .
Old 07-19-2012, 03:53 AM   #7
robertcdf's Avatar
Doesn't sound like a professional to me, sounds like a handyman. Did you check references? What's his website? Did you go and look at previous projects that were similar to yours? I bring most of my potential clients to a project (or multiple projects) before we sign a deal.
The Following User Says Thank You to robertcdf For This Useful Post:
JoeCanning (07-19-2012)
Old 07-19-2012, 07:41 AM   #8
no website.... knew his work and the work of his father.. knew him for many years.. first time we hired him usually his father did the jobs for us. but I think bc he knew us... he didn't think we would care how it was done bc we needed it done fairly quickly bc mom had fall off the steps that came with the house. thanks for the advice... we are going to just take off what he has done . . fix banisters and not worry about a roof. now when we do will run the boards from the ground attach them to the porch and up to the roof..
Building a Gable end porch cover. Tying into existing roof d354u73l Building & Construction 20 08-26-2016 03:08 PM
Insulating flat roof deck paredown Insulation 0 05-15-2012 05:33 PM
put roof over existing deck ljkoste Roofing/Siding 2 08-20-2011 03:03 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Free-Standing Deck with Screened Porch Tied into existing Roof butlerbach Carpentry 2 05-14-2009 08:25 AM
