#16 |
JOATMON
Adding Gable End Overhang
Here is what mine look like....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 |
Doing This Way Too Long
I don't see any reason to modify those. Tearoff, repair as needed and re-roof.
#18 |
JOATMON
The biggest regret I have with my garage was not putting on a longer gable end........If I'm still in this house 20 years from now about which time the garage will be ready for a new roof....I'm going to lengthen the gable end....
#19 |
Adding Gable End Overhang |
#20 |
JOATMON
No....but the wood was primered prior to install...then primered again...then painted....I have a drip edge that was installed 'after' the painting....I have found that to extend the life a bit....
Metal Wrapped? Have not heard of that....most likely worth looking into....but then again....I live in California....the hardest thing on my paint is the sun. I know I'll have to paint them in about 5-8 years. This pic is about 2 months old....but will give you a better idea of the overall look.
#21 |
Looks to me like the rake boards are rotting because of little to no shingle overhang, adding drip edge up the rakes would help, too.
#22 |
Roofmaster
First of all, you dont need to go through all the work that you are going to get into. Your problem has to do with how your rakes were handled originally. You did not mention cladding of your fascia and rakes with white aluminum.
What you need to do is to replace your rotten wood with pre-primed pine, Clad your rakes and fascia with white aluminum, Install a decent drip edge which is properly enveloped with ice dams flashing, and make sure your shingles overhang drip 1 inch minimum. Considering the height of your roof from the windows, the overhang will not keep wind blown rain from hitting them, and properly detailed siding with a proper secondary protection will not leak.
" A lot of men build things, and a lot of things fall down " |
#23 | |
Adding Gable End OverhangQuote:
I will try and take a close picture of the drip edge and gutters later this week. |
#24 | |
What do you mean by secondary protection for the siding? If you are talking in regards to house wrap, I do not believe there is any. 25 year old home. I have replaced siding and some of the sheathing because the home owners let the corner boars rot all the way through and through the sheathing. Why I was thinking that I need a gable end overhang was because all of my corner boards are in horrible shape. They seemed to keep up with the paint, but lots of rot on the corner boards. I have replaced 3 corners already (out of 6) and I didn't want it to continue. I figured protecting any of the exterior from rain would be good! |
| Tags |
eaves, gable end, new roof, overhang, rake boards ![]() |
| Display Modes | |
| Ventilation - Opposing gable, limited soffit + box vents = Screwed up? | darlingm | Roofing/Siding | 1 | 09-07-2011 11:13 AM |
| adding workspace addition to a gable style garage | builderzone | Building & Construction | 2 | 09-05-2010 05:22 PM |
| Adding Gable porch in NNY | webweever | Roofing/Siding | 0 | 04-18-2010 08:27 PM |
| question about gable overhang framing | wombosi | Building & Construction | 11 | 04-09-2009 12:44 PM |
| tight overhang clearance on gable abutment - how to cover...? | rtoni | Roofing/Siding | 7 | 10-12-2007 12:13 AM |
