Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-19-2012, 04:11 PM   #1
Question
Adding drip edge to low-pitch patio roof
Hi - During a recent storm I noticed the patio roof (low-pitch, roll roofing) was dripping quite a bit despite the presence of a gutter and downspout. Climbing the ladder revealed that there is no drip edge installed.
(As an aside, I feel a little silly because this was noted in the inspection, I asked for a repair and then approved when I saw they had installed it along the pitched ends of the roof. It hadn't occurred to me that the edge with the gutter would need one too.)
It looks like the roll roofing was installed to hang an inch over the gutters, but of course, that's not how water works and it has been coming back under, soaking the OSB and running down the fascia board.
I feel pretty confident I can handle this install, but I have some questions (based on the photos below): Should the drip edge be installed a) flush with the existing roll roof edge, b) flush with the OSB sheathing, c) just as long as it's over the gutter who cares? If the answer is "b", should I cut the roofing material back to be flush or create a specific overhang? As you can see from the photos, there is a line of nails right at the edge that will need to be removed for installation of the drip edge. Do I reinstall those when finished, or use some other form of fastener or adhesive?
Anything else I'm missing?
Thanks in advance!
Joboo
Joboo is offline   Reply With Quote
Old 02-19-2012, 04:22 PM   #2
#1 in my opion roll roofing should never have been used. It's one of the lowest classes of roofing, you would be lucky to get more then 5 years out of it. I would not use it on a chicken coop.
With that low a slope it should have been EPDM, metal, PVC.
With all those exposed nails no wonder it's leaking.
Adding the drip cap will do little good.
tinner666 (02-20-2012)
Old 02-19-2012, 05:14 PM   #3
Doing This Way Too Long
Agreed, sorry but that whole roof is terrible and just putting drip edge on is not going to do much. By the time you do it properly you might as well do the whole thing.
IF you can do a proper transition to the upper pitch, a standing seam (not rolled rib) roof would be a fairly easy and effective system there. Difficulty depends partly on how badly the sheeting and fascia are rotted away from the exposure it's been getting.
I wouldn't be surprised if a good chunk of your problems is the roof itself and all those exposed fasteners and not the lack of drip edge. The latent water surrounding the nail heads is an indication that every one of those is sucking water.
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Old 02-20-2012, 06:38 PM   #4
Pro Slate Roofer
tinner666's Avatar
They're right. It needs to be roofed with real roof material.
tinner666 is offline   Reply With Quote
Old 02-20-2012, 11:28 PM   #5
OK. I'll replace the roof. In February. In Oregon.
This is why houses fall apart. People come looking for help and get berated for having the audacity to have a crappy house in the first place. I humbly apologize for living in a chicken coop and I hope you forgive me.
I realize the roof is crap and uses low-quality materials. I realize that it will need to be replaced. Right now though, it's raining and I want to prevent any more damage to the parts of the roof that are salvageable. Apparently I wandered into an episode of Holmes on Homes.
Old 02-20-2012, 11:32 PM   #6
Then just put some Black jack roof sealant on the nail heads.
seeyou (02-24-2012)
Old 02-20-2012, 11:54 PM   #7
Ummm, WOW!
Old 02-24-2012, 08:00 AM   #8
Roofer Mike
Why hate on the material. Can't tell what it is. Probably just some cold-applied 90lb. or mineral cap which in Miami roofers sell just to get the job.
But it could be a modified cap which, as part of a well-designed BUR, is a practical residential roofing system. Judging by the pic I doubt it.
Could install a drip-edge and strip it with something.
Then bless it...
roofermikeinc is offline   Reply With Quote
Old 02-24-2012, 08:40 AM   #9
Tom Struble's Avatar
Tom Struble is offline   Reply With Quote
Old 02-24-2012, 09:05 AM   #10
Exterior Construction
Windows on Wash's Avatar
The Holmes on Homes comment is quite funny.
Old 02-24-2012, 09:52 AM   #11
Could cut back the edge, install drip edge and 3-course it or something but it would just cause new problems. We tell him drip edge isn't his only or main problem and he acts like we just killed his cat.
BTW I am writing this in my motel room...on the Oregon coast...roofing in Oregon...in February. Just sayin'
As far as the material Mike; Can tell by looking at it what it is and just because some roofers sell something that doesn't make it a good product. (just look at TPO ) Oh prepare for the firestorm.
From the pictures it appears to be over an outside space. It is a fairly small and simple roofdeck for a DIY which is why I suggested looking at doing the whole thing correctly. Since the OP informed us it is a chicken coop then that makes it even easier to do in February.
Old 02-24-2012, 10:38 AM   #12
Shut in w/o Home
seeyou's Avatar
He was gonna move, but he needs the eggs
seeyou is offline   Reply With Quote
Old 02-24-2012, 10:46 AM   #13
Shut in w/o Home
seeyou's Avatar
Actually, you've been given good advice. It's more likely the nails that are letting the water in to the edge of the sheathing. Tarring them up is more likely to buy you some time than trying to add drip edge under a roof in questionable condition.
As far as the berating, it didn't actually happen. Most of the answers you got are from seasoned pros and they've seen this scenario many times. The roll roofing that you have on that low of a slope is maybe a 5 year roof. For what it costs to do it twice and repair the damage that ensues when it starts to fail, you could have a 20+ year membrane roof.
Good luck and that Holmes comment was a good one.
rubber roof over tar & thoughts on quote wfmrules3 Roofing 13 10-16-2011 10:00 PM
How do you install a drip edge on a pre-existing roof? gjeka Roofing 9 09-21-2011 06:48 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing 4 10-07-2009 11:49 AM
Adding a roof over a bulkhead? 1parkpointer Building & Construction 1 12-08-2008 10:24 AM
Adding a gable porch to a pitch roof fjacky Building & Construction 5 08-09-2005 07:56 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
