Adding A Dormer - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-10-2006, 09:50 AM   #1
Adding a Dormer
I'm adding a large dormer to an existing finished roof. When I get to roofing, is it possible cut existing roofing along the valley line and work the valley flashing up under the existing comp shingles or do I need to remove all the shingles above the new valley?
Thanks in advance
ffishmonger is offline   Reply With Quote
Old 02-10-2006, 07:44 PM   #2
Commercial Roofing
AaronB's Avatar
Can you provide any more detail?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 02-10-2006, 08:08 PM   #3
renovations
Unless there are unforseen details, that is what I have generally done. I cut the existing shingles so that the cut line ends up 3" from the centre of the valley. Then very carefully get any nails out that will be in the way of the flashing, pull any staples in the roofing felt and slide the flashing up after the dormer is framed and sheathed. Certainly re-roofing the whole side will give you the absolutely best job, but I have had no problems with a retro-fit.
Bonus is offline   Reply With Quote
Old 02-11-2006, 12:13 AM   #4
Thanks Bonus, How wide of valley flashing have you had success with in sliding under existing shingles after making your cut? I'm working with a 4-12 pitch.
Old 02-11-2006, 10:02 AM   #5
Commercial Roofing
AaronB's Avatar
Are you adding on in the valley?
Old 02-11-2006, 11:11 PM   #6
I am actually making a new valley by attaching a new roof perpendicular to an existing one. The attaching roof meets at the peak and eave of existing roof.
Old 02-11-2006, 11:41 PM   #7
renovations
I generally use 24" valley flashing with a 'w' profile, (so there's an inverted 'v' running down the center of the valley). This gives you 12" each side.
Adding a dormer...estimate? wease Remodeling 2 12-11-2006 03:17 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
Adding Dormer(s) Rusty Bottoms Carpentry 3 12-07-2005 07:31 PM
adding a second floor chubdo Building & Construction 11 04-16-2005 12:20 AM
