Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-08-2013, 12:45 PM   #1
Adding deck roof to existing metal roof
I have a 9/12 metal roof on my house and have a small deck running parallel to the ridge that is 9 feet by 30 feet. I have a 6" fascia and would like to add a roof to cover the deck. Can I attach the rafters to the existing metal roof and attach the level part of the rafters to the fascia board? If so, what type of interface do I have to have on the metal roof where the slope will change to join the two sections of roof? Attaching a file to give a better idea of what I want to do
billybarty is offline   Reply With Quote
Old 03-08-2013, 06:15 PM   #2
Metal Roofing
You would typically remove the roofing to attach your new framing to the existing framing under the existing roof.
What type of metal roof is there now? This will determine how you address the roof transition between the old and new. If you need to remove all the roofing at the proposed roof transitions or just some is the determining factor. The roof type is critical given what you propose...we need to know.
AndyWRS is offline   Reply With Quote
Old 03-08-2013, 07:50 PM   #3
Roofmaster
What does the "Level Part of the Rafters mean?
What kind of roof is going on the new slope?
You need to cut the metal roof back up slope about six inches above where the plane of the new roof will tie in the the existing, Put a 2 x 10 or so plate accross the rafters at the tie in, and run the new rafters past the top plate of the outer wall to create a soffit and eaves beyound the outer wall You will cut a birds mouth in the rafters to sit flush on the wall. You will need S clips and a continuous apron to run up under the existing metal roof into the S clips which covers down over the ribs of the roof below. You would cut openings in the sheathing below the tie in to allow air flow up through the soffit, new and main rafters.
" A lot of men build things, and a lot of things fall down "
adding a gable roof..to an existing deck helloitsme21 Roofing 7 07-19-2012 07:41 AM
Multi rib metal roof on double wide...static vents wpilotm Roofing 0 09-10-2011 04:51 PM
Adding stairs or ramp to existing deck cluelessone Building & Construction 3 07-10-2011 05:39 PM
Attaching a shed roof to an existing roof. JMcLaughlin856 Building & Construction 2 03-13-2011 10:25 PM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing 10 02-02-2010 01:18 AM
