Adding Attic Vent W/existing Ridge Vent - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-04-2009, 01:43 PM   #1
Adding attic vent w/existing ridge vent
Hi Folks,
I have a ~new (2007) house here in Georgia, and I'm looking for ways to cool off my attic during the brutal summer months. I currently have soffit + ridge vents, but I'm wondering whether some roof vents (probably solar) would help? The attic is ~1500sqft, and currently has R30 insulation.
In the summer, the upstairs central air unit runs nearly constantly, and I'd like to make a dent in the awful electric bill. I'd appreciate any pointers!
Thanks!
GeorgiaGeek is offline   Reply With Quote
Old 05-04-2009, 01:47 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Gable vents are easy to do. Some can be powered as well. If you have a roof/attic design that will lend itself to gable vents I would go that route.
Brik is offline   Reply With Quote
Old 05-04-2009, 01:50 PM   #3
Unfortunately the roof doesn't really have any gables. The only one is over the (uninsulated) garage, and it already has one.
Old 05-04-2009, 02:09 PM   #4
Handyguy
Brik's Avatar
I'm assuming your soffit vents are not blocked. The key to a ridge vent working well is having an equal, or greater opening at the soffit. Same will hold true with adding roof vents. Powered roof vents will possibly work better if your soffit vents are limited but will require a certain amount of intake. I don't generally care for roof vents because they are one more hole in your roof that could leak if installed incorrectly but in your case they may be your only option.
Here are a few to consider
Solar
http://astore.amazon.com/handyguys-20/detail/B001AH3C66
Electric
http://astore.amazon.com/handyguys-20/detail/B000LDIWPG
Passive turbine
http://astore.amazon.com/handyguys-20/detail/B000HE4RSA
Passive duct type
http://astore.amazon.com/handyguys-20/detail/B000BQOA8Q
Old 05-04-2009, 02:29 PM   #5
Thanks for the reply... that makes sense. There should be enough air from the soffit, but I'll check and make sure there aren't any blockages.
So, is it possible to add too much ventilation? I assume at some point there are diminishing returns....
Would a radiant barrier be any help? How does it get applied with the existing blown insulation?
Old 05-04-2009, 02:39 PM   #6
Handyguy
Brik's Avatar
I'm not sure I am a fan of radiant barriers. Others may disagree but I think my first choice would be venting.
Old 05-05-2009, 02:04 AM   #7
How are you sure that there is enough Soffit Intake Ventilation?
How many and what size do you have?
Unless you have 100% continuous soffit vents, then over 90% of the time, you will be substantially under ventilated for Intake.
Ed
Ed the Roofer is offline   Reply With Quote
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
HOT attic, ridge vent/soffit vent questions gone_fishing Roofing/Siding 36 07-14-2008 09:26 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
