Add Ridge Vent? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-27-2012, 03:35 PM   #16
Rewards Points: 43
I was in the attic while the whole house fan was running and found it wasnt nearly as "windy" as expected. I couldn't even feel it at one end. The air just gets forced out wherever the openings are. I easily could close off two louvers w/o affecting it.
"On paper", adding a ridge vent w/ a few add'l soffit vents would be enough to exhaust the house fan, with the gables permanently closed.
I did find all the soffit louvers at least partially clogged with dust. I removed and washed the low ones, and used compressed air with a 4' wand on the ones too high to remove. It is a tedious job!
The louver blades all face the house, which helps pick up the webs that always collect under the soffit. I guess having the louvers face the house better takes advantage of a high pressure area under the soffit?
Al
AlleyG is offline   Reply With Quote
Old 08-27-2012, 03:43 PM   #17
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Al
It's purely cosmetic. Facing the house looks smoother from the exterior.
seeyou is offline   Reply With Quote
Old 08-28-2012, 01:05 AM   #18
Registered User
Rewards Points: 4,914
"The louver blades all face the house, which helps pick up the webs that always collect under the soffit. I guess having the louvers face the house better takes advantage of a high pressure area under the soffit?"---- Yep, the better wind is away from the house, next to the fascia board, less rain, snow, dust; pp. 616: http://books.google.com/books?id=Z8a...0vents&f=false
Double-direction continuous venting, you can't go wrong...LOL. They should face out, as you learned...I didn't know until I read it while researching a few years ago.
Gary
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 04:47 PM
Is it common for roofers to NOT slice underlayment on a ridge vent before installing? jcarlan Roofing/Siding 29 01-05-2012 04:26 PM
Roof ventilaton - hip roof (ridge vent, fan, power vent ?) rkpatt Building & Construction 2 06-02-2011 05:21 PM
Ridge vent shingling..How to do it properly? J S Machine Roofing/Siding 5 01-18-2011 12:58 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 11:50 PM
