Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-25-2011, 12:56 PM   #1
Add a ridge vent?
I recently had some storm damage to my roof and will be having the shingles replaced in the next couple of weeks. My house is a early 90's construction and has gable vents and what appears to be soffit vents in the overhangs (vinyl siding with holes punched).
My question is should I have a ridge vent added or leave it as is? The estimate didn't include it I assume because I have an existing ventilation system (soffits and gables). I asked the contractor about it and he said it couldn't hurt, but he wasn't sure if it would help...
Any suggestions?
mrwilliams2 is offline   Reply With Quote
Old 04-25-2011, 01:00 PM   #2
Framing Contractor
Add a ridge vent?
In the last few years I have heard many people say that in you have the ridge vents, then you should cover up the gable vents. If not, it can disrupt the whole flow of air in the attic. The ridge vent works much better than the gable vents. Since you are having the roof done anyways, it is not an expensive addition. I would go into the attic afterwards and close up the gable vents with plywood. Doesn't have to be 100% sealed, just enough to stop large air movement.
sixeightten is offline   Reply With Quote
Old 04-25-2011, 01:18 PM   #3
Shut in w/o Home
seeyou's Avatar
Add a ridge vent?
That's pretty much an old wife's tale. If you have a ventilated roof system, you'd have a hard time installing too much venting.
With ridge vent AND gable vent, the worst case scenario is that air enters the gable vent and exits the ridge vent reducing the pull from the soffit vents. But you'd still be getting air movement which should remove the moisture. If you're relying on attic venting to keep the inside of the house cool, then you don't have enough insulation.
seeyou is offline   Reply With Quote
Old 04-25-2011, 01:22 PM   #4
Add a ridge vent?
As far as I know, I haven't had any trouble whatsoever with the system that is in place currently. I don't have a problem with moisture buildup, but it gets sweltering hot in the attic during the summer months. The attic is used for storage only. The roofer said that he could install a ridge vent for around $300 bucks while the shingles were being replaced. I figured that would be a pretty cheap addition. If it will be beneficial, I'll do it. If it won't be helpful, I'll hang onto my $300.
Old 04-25-2011, 01:25 PM   #5
Shut in w/o Home
seeyou's Avatar
Add a ridge vent?
If you have no moisture problems, spend that $300 on insulation. I've seen very few buildings (including my own) in my 30+ year career that couldn't benefit from some more insulation.
Old 04-25-2011, 01:31 PM   #6
Moderator
Add a ridge vent?
More ventilation in the attic will reduce the cooling load. Personally, I would add the ridge vent (baffled) and leave the gable vents alone if they are 3' or more above the soffit vents. Depends on the wind direction for so-called "short-circuiting". I would open up the soffit vents more as the perf's are minimal; http://files.buildsite.com/dbderived...rived92755.pdf You want 9 NFVA per foot of soffit (per side) to match the 18 NFVA of exhaust; http://www.airvent.com/homeowner/pro...it-specs.shtml
http://files.buildsite.com/dbderived...rived20936.pdf
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
new roof, ridge vent was in est, but not installed... Zel1 Roofing 29 09-01-2010 05:30 PM
Shingling over ridge vent -details needed jogr Roofing 4 11-06-2009 06:47 PM
Hip caps to ridge vent KEITHnhia Roofing 1 07-04-2009 02:17 PM
Ridge Vent on a Shed jokiddjr Roofing 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing 15 02-22-2008 12:35 AM
