Add New Shed Roof To Existing Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-04-2011, 06:21 PM   #1
add new shed roof to existing roof
I am adding a new shed roof over my 20x20' concrete deck. Is the proper way to run say a 2x8 across the 20 ' span and attach 2x6 rafters from the piece of wood? I was only going to support the roof from the outside walls (no center supports) - is that OK? What should the span be between each of the rafters?
Obviously I need your help which I really appreciate.
Thank you,
Chuck
charring6 is offline   Reply With Quote
Old 07-05-2011, 06:13 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
For a 20' clear span, you'll need an engineer to spec the correct size steel beam AND the correct specs for the two corner footings. That'll be a large point load on each corner. Possibly 6' of concrete, 2' wide, or more. ( Just gessing there)
tinner666 is offline   Reply With Quote
Old 07-05-2011, 08:33 AM   #3
new roof addition to existing roof
Thanks for your reply.
I apologize for not being more exact on what I was thinking about going.
I was going to put 4x4 posts around the front and sides of the shed roof say every 4 feet to support the rest of the roof. I was concerned that being I would have no supports in the center of the span if that would be a problem?
Thank you,
Chuck
Old 07-05-2011, 12:54 PM   #4
Pro Slate Roofer
tinner666's Avatar
Without knowing where you are from and if snow load is an issue, 2x6 can span 20'. Me, I'd prefer 2x8's and you really should mount doubled 2x10's on top of the posts, and set the rafters on top of that.
You might want to take this to carpentry/framing to get more specs.
Old 07-05-2011, 01:18 PM   #5
Thank you very much.
Fortunately I am in Atlanta so we do not get a lot of snow here. I was thinking about using the rolled rubber roofing. What do you think? If I used rolled rubber do I have to put felt paper under it?
Old 07-05-2011, 03:49 PM   #6
Pro Slate Roofer
tinner666's Avatar
You'll have to explain 'rolled rubber roofing'.
EPDM doesn't get felt.
SBS has anailable base sheet and an inter-ply for adding layers, then it has a cap sheet.
TPO need to be welded.
APP needs to be torched down.
I'm not even familiar with PVC.
You can call my 232 number if you want. I'll be around for a short while.
Tags
new roofing
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Shed Roof Questions jobondur Roofing/Siding 1 10-04-2010 11:52 AM
shed roof over old deck bluegrass General DIY Discussions 3 09-12-2009 02:03 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 07:11 PM
HELP - Finishing Row on a Shed Roof Makes More Work Roofing/Siding 5 06-25-2008 06:27 PM
