8 X 48 In Soffit Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-02-2012, 07:43 PM   #1
Red face
8 x 48 in soffit vents
We recently had our roof redone but several of our soffit vents were 8 x 48 inches. We need help in locating this size for replacements. Can anyone help? These are just plain vented covers to go over the vent holes in the soffit. Please help.
jmrausch is offline   Reply With Quote
Old 06-02-2012, 07:48 PM   #2
Rewards Points: 6,652
Why did the roofing company remove the soffit vents in the first place? Can you post pictures, so that others can see what you are seeing.
Old 06-02-2012, 08:13 PM   #3
Rewards Points: 13,458
I've never seen any that big, sure there not just cut out areas in the plywood with screening behind them?
A picture as suggested should clear it up.
Old 06-03-2012, 04:58 PM   #4
Here is the picture cing
It is pretty ragged and needs replacing. We have to replace 4 of them.
Old 06-03-2012, 05:06 PM   #5
With those off it would be a perfect time to add vinyl soffit vents and wrap the fashias in coil stock.
Old 06-16-2012, 11:52 AM   #6
I have the exact same need for this size vent. It is on a ranch house built in 1962. I have not been able to find various length vents. Need some 48" vents. I have thought about trying to buy shorter vents and butting them together but that is not the most pleasing option from a visual standpoint. Surely someone still makes these!
vball is offline   Reply With Quote
Old 06-18-2012, 12:33 AM   #7
Registered User
Rewards Points: 5,492
Those are way too big for 9 NFVA per foot of soffit: http://www.airvent.com/homeowner/pro...it-specs.shtml
Wind would enter one and out the next one if an easier path. Continuous venting as the link said, is best.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
mae-ling (06-18-2012)
Old 07-03-2012, 03:12 PM   #8
Thanks for verifying my need. My husband tried to cobble three vents together but it just didn't work. he is trying to fix the existing ones :-(
Pretty sad. I can't believe that no one can find these.
Old 07-03-2012, 05:12 PM   #9
Thanks for the update. The house is 50 years old but the brick looks great, the roof had hail damage and was recently replaced, and I painted the trim. So everything looks fine except for these original vents which have been painted multiple times. House has been in the family for the whole 50 years and we never had ventilation or heat buildup issues. Don't want to tear up perfectly good soffits to install a completely new ventilation system. Just want some simple replacement vents!
Tags
soffit vent , soffit vents
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 09:12 AM
Ridge Vent with No Soffit Vents? Is it possible? NTL1991 Roofing/Siding 4 05-14-2012 02:08 PM
Hidden Soffit Vents Mucluk Building & Construction 4 01-26-2012 08:15 AM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 04:12 PM
