7/16 Sheathing/trusses Spaced 24" - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 12:57 AM   #16
Rewards Points: 12,802
What your going to see from the attic is just a strip of aluminim about 1/2 wide between every row of OSB.
If you had one in your hand it just looks like the letter H and should say 7/16 right on it most of the time.
It also allows for the 1/8" gap needed between the panels to allow for expantion.
Old 09-03-2012, 09:43 AM   #17
Roofing Contractor
I've worked on hundreds of houses with 7/16in OSB with 24in OC trusses. Most have H clips but once in a great while there is no H clips present. What will occure without H clips is the decking can buckle. The buckling is more common with plywood however and typicaly not that bad with OSB.
My primary home is a 7k sq ft home built in 03/04 with 7/16in OSB with trusses 24in OC with H clips. I sleep just fine at night!!!
dougger222 is offline   Reply With Quote
Old 09-03-2012, 10:54 AM   #18
Rewards Points: 2,202
As others have said 7/16 2'OC rafters and H clips are common.
I have been in 5 provinces and all were this way.
*** As stated below please ignore this it is bad advice, left it here so the comment below would make sense.***
If there are no H clips you could use PL400 or the like and glue plywood scabs/backing on all the joints, Say 1/2" thick and 6" wide.
Although there does need to be a gap between the sheets.
mae-ling is offline   Reply With Quote
Old 09-03-2012, 09:19 PM   #19
Registered User
Rewards Points: 4,902
No glue/plywood, they have to expand/contract at the edges. You may need them, OR NOT: http://www.strongtie.com/products/co.../pscl-psca.asp As said, read the rating ink stamp on the panel, then add 2x blocking- if needed.
Gary
Old 09-04-2012, 11:29 AM   #20
Maybe I should not post advice when worked 21 days and now on nights!
24" x 24" Granite Tile ddean1028 Building & Construction 4 01-27-2011 07:44 AM
