60 Square Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-20-2013, 07:14 PM   #1
Rewards Points: 81
60 square roof
I decided to bite the bullet and put a new roof on. Can anyone recommend a very professional and reputable company. It's a low pitch rolled roof and I prefer metal. I will need a completely new gutter system, some beams and plywood replaced in certain places, new skylights 2-4, new fascia and soffits. Also want to make sure the attic spaces are vented properly. House is about 90 ft by 50 one story with plenty of access all around.
Also is there anything else I should consider while it's being replaced like lighting, new vents, solar panels etc? I just want to prep myself so I don't get taken for a ride.
r1racer is offline   Reply With Quote
Old 09-20-2013, 07:42 PM   #2
Metal Roofing
Rewards Points: 600
Your location?
AndyWRS is offline   Reply With Quote
Old 09-20-2013, 08:14 PM   #3
Rewards Points: 81
That would be helpful. Upper Marlboro, MD.
Old 09-20-2013, 08:38 PM   #4
Roofmaster
Rewards Points: 2,172
The type of metal roof you can use depends on the slope.
Control Roofing and Sheet Metal.
They used to be in Capitol Heights, but now they are in Linthicum. PM me and I will give you a contact.
Pricing a 1 layer tear off of a flat roof. Then installing 1-1/2 thick insulation and 60m. thick EPDM. I need a price per square on labor and materials. Thank you. Tim. pete1700 Roofing/Siding 11 07-19-2011 09:31 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
