45" Span - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-30-2011, 03:19 PM   #1
45" span
I want to span 36' with a 6X6 HSS
there is no roof or floor load on the span. 10' per foot show load
canopy roof will 15 feet below also with a 10' snow load.
the beam is 46' with two 5' sheer supports on both sides
I worried about the beam buckling under its own weight.
Futurearchitect is offline   Reply With Quote
Old 01-30-2011, 03:38 PM   #2
Experienced
Jackofall1's Avatar
Haven't run the calc's but I would say, that a 6 x 6 of unknow thickness wouldn't span 36', there are beams that would able to span 36' with the right cross section.
Given your screen name "future architect" I would think that you are close enough to someone with enough engineering knowledge to size the member you need.
Mark
Old 01-30-2011, 03:41 PM   #3
Civil Engineer
Rewards Points: 4,560
You need to post a carefully drawn diagram with your comments, I can't figure out what you are talking about. As for the loads, do you mean 10 pounds per square foot of snow load, or have you computed the snow load as 10 pounds per linear foot? And what is a sheer support, are you using nylon stockings to hold up the end of the beam?
As for the beam buckling under its own weight, are you planning to compute buckling load, or are you concerned about bending? Buckling is very complex to compute, bending is easier, but you still need a very carefully drawn diagram, and careful analysis of the actual load on the beam, before you can calculate the factor of safety against buckling, bending, and shear.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
AndyGump (01-30-2011)
Old 01-30-2011, 03:44 PM   #4
Experienced
Jackofall1's Avatar
OMG......LMAROTC
Old 01-30-2011, 04:35 PM   #5
Well I sure know what this place is all about
I new this would fail. I was just testing the site.
Telling all my friends not to use this forum.
tx.
Old 01-30-2011, 04:39 PM   #6
Steeler99's Avatar
I wouldn't use an HSS, I'd just a WF with plates welded to the sides to make it appear to be an HSS. A general rule of thumb would be take the span and divide it by two, that's the minimum height of the beam that you need. That's for floor loads. But consult with a PE, I wouldn't chance it
Steeler99 is offline   Reply With Quote
Old 01-30-2011, 04:48 PM   #7
Experienced
Jackofall1's Avatar
tx.
What did you expect, really, there isn't any usable information in your initial question.
Like Daniel said, do up a sketch, post it with a well thought out explanation and then you will get a qualified answer.
Mark
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 2 02-24-2015 07:50 AM
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
Platform across a 9 foot span Hogan-s Carpentry 1 09-19-2008 08:46 AM
