4/12slope Ridge Vent? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-28-2008, 09:36 PM   #1
4/12slope ridge vent?
I have a ranch w/ 4/12 slope, 1200 sq.ft. w/ 4' overhang with soffet vents. Am re-roofing but heard ridge vents should not be used on 4/12 slope. Have gable vents which I assume should be blocked if ridge vent used. Michigan climate. Thanks
mitch33 is offline   Reply With Quote
Old 04-28-2008, 10:54 PM   #2
I have used the plastic interlinking Cobra system made by GAF on some pretty low slopes. We prep the ridge with a layer of ice/water, then make slightly oversized cap from the regular architectural shingles we used on the roof, I think this method has been used about 4-5 times over past 3 years, cant recall any repairs. Gable should be sealed and eve vented, but many customers lately have been making up their own rules so it seems almost anything will work ok, but they end up not using the ridge vent capability, to its full capacity.
gusthehonky is offline   Reply With Quote
Old 04-28-2008, 11:03 PM   #3
Thanks Gus: What do you mean by "prep with ice/water"?
Old 04-28-2008, 11:11 PM   #4
[quote=gusthehonky;119780]I have used the plastic interlinking Cobra system made by GAF on some pretty low slopes. We prep the ridge with a layer of ice/water, then make slightly oversized cap from the regular architectural shingles we used on the roof
Thats ugly,architectural shingles cut up for ridgecap.Seen it,what an eyesore,IMO.
johnk is offline   Reply With Quote
Old 04-28-2008, 11:26 PM   #5
I know, funny looking but ends being tough to see because of slope. Really just do it to gain that tiny bit to give that channel a bit more cover.
Old 04-28-2008, 11:32 PM   #6
I see where your coming from,why not try weatherpro by duraflow,good from 3 1/2-14/12 has a baffle system that wards offsnow and driving rain
Old 04-28-2008, 11:35 PM   #7
Ice/Water is a protective layer placed under first layer, atop any drip edge, in valleys, and a bunch of other places where there is a higher potential for leaking, pooling or ice daming up. Its kinda like a rubbery version of the grip tape used for traction on handicapped ramps. Really good stuff, and is required. Can be very temperamental in the hotter months, don't get it stuck to itself or you.
Old 04-28-2008, 11:41 PM   #8
Not full partner, & its roofing!: sane and logical ideas are met with brutal opposition, resistance to change is a mantra.
Old 04-29-2008, 01:45 PM   #9
I use the Shingle Vent II all the time on 4/12 pitch roofs, like at least 20-30 of them per year, with no problems and no additional steps to make sure it works.
For times on a 12/12 cape cod, which has a 2/12 flat roof dormer on the rear side, I install a J-Channel inside of the ridge vent to act as an intenal baffle to deflect any potential moisture, water or snow, intrusion concerns.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-29-2008, 02:15 PM   #10
Here are some photos of the Smart Vent for intake, placed, along the eave edge on one side and as a mid-roof application on the other side and using the Shingle Vent II Ridge Vent on the entire ridge line.
http://www.contractortalk.com/showthread.php?t=37659
Ed
Old 04-30-2008, 01:01 AM   #11
the roofing god's Avatar
Send a message via MSN to the roofing god
never a problem with a ridge vent on that pitch,yes close the gable vents when using both ridge and soffit vents to requirements
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-22-2008 12:35 AM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 10:57 PM
Ridge vent installation cost Douche Roofing/Siding 1 07-26-2006 05:59 AM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 09:32 PM
