Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-18-2011, 01:47 PM   #1
38' Gutter
The back of my house spans 38 feet long. I have the gutter that was there is 38' long is that too much to have one downspout? or should I split it? What do you need to have for inch per foot? 1/8th inch per foot?
klrz28 is offline   Reply With Quote
Old 03-18-2011, 02:15 PM   #2
38' Gutter
I usually try to shoot for at least 1/8" per foot, for any application that involves channeling water, but, with eaves trough, aesthetics sometimes preclude that much. Nevertheless, for a 38' run, I would definitely go for two downspouts. You could have one at each end, but, again, for aesthetic purposes, I would look at placing them 9-10' in from the end, so that, using 1/8" per foot as an example, you would have a maximim drop of 1-1/4" in a ten foot length of eaves trough, versus 2-3/8" in a 19' run of it.
Old 03-18-2011, 02:51 PM   #3
38' Gutter
If you're going to add a downspout, you might as well make them both 3x4.
handy man88 is offline   Reply With Quote
Old 03-18-2011, 08:01 PM   #4
Shut in w/o Home
seeyou's Avatar
38' Gutter
38' is too long for one downspout unless it's in the middle. Then it depends on how much roof is feeding it, gutter size, & downspout size.
In a situation with only one downspout at the end of a gutter run, you should strive for 1/8"/ft. If you have a downspout at either end, you can get away with hanging it almost level.
seeyou is offline   Reply With Quote
Gutter installation questions Homerepairguy Roofing 7 03-15-2012 11:22 AM
Gutter installation along drip edge questions: Nor-Cal Owner Roofing 4 02-02-2011 10:26 PM
Gutter Apron DePasquale Roofing 3 11-25-2010 06:54 AM
Rain gutter slopes the wrong way ovahimba Roofing 2 12-20-2009 04:56 PM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 07:07 AM
