A 30 Foot Span Trusses Able To Hold 6 Feet Of Snow - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-16-2010, 08:58 PM   #1
a 30 foot span trusses able to hold 6 feet of snow
l want to reinforce my roof, half the house has no division accross the trusses. one idea is adding more to the w frame, or framing another trusses beam inside the roof accross the trusses that would sit on the bottom member of the actual strusses and the top of my new beam would fit tighly under the top ridge gusset. inside the house under my new beam, l would add a post 10' feet apart
bertr is offline   Reply With Quote
Old 07-16-2010, 09:48 PM   #2
Post a diagram or photo. The roof construction and angles need to be specified.
http://www.classictruss.com/art/wodd...s_examples.gif
Old 07-16-2010, 10:19 PM   #3
Rewards Points: 1,908
That doesn't sound like it would help much for snow load. Find out who designed your trusses and see what snow load they were designed for. They should be able to tell you the best way to add load capability.
Building Garage with Engineered Trusses twiles Carpentry 28 11-26-2015 11:24 PM
Pre-Manufactured Trusses or not? my5sons Building & Construction 7 04-13-2012 01:44 PM
what kind & size floor joists needed to span 15 feet? redss Building & Construction 17 07-11-2009 06:02 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 09:47 AM
open span under hipped roof..... SickPuppy Carpentry 3 06-06-2008 12:24 PM
