#30 Felt Vs. 30lb Felt--What's The Difference? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-18-2011, 05:46 PM   #1
Rewards Points: 654
#30 Felt vs. 30lb Felt--What's the difference?
#30 Felt vs. 30lb Felt--What's the difference? Just called something different? Same thing? One better/worse?
kennykenny is offline   Reply With Quote
Old 04-18-2011, 05:55 PM   #2
kwikfishron's Avatar
Rewards Points: 86
30 lb. felt weighs 30 lbs per square. 15 lb weighs 15 lbs per square. That’s was back in the day, like with everything else getting scaled back it’s now called #30 felt which is about the same as what 15 lb. used to be.
I’m not even sure if 30 lb. is still available.
kwikfishron is offline   Reply With Quote
Old 04-18-2011, 06:18 PM   #3
Rewards Points: 654
so if I two estimates and one says #30 and the other says 30lb, they aren't the same? If I understand you correctly? Thanks.
Old 04-18-2011, 06:34 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
It's now #30 felt. Some people still call it 30#. My local options are #15 or #30. A 2 sq roll used to weigh 60lbs. It doesn't anymore.
I mostly use synthetic underlayments. A lot of people call them synthetic "felt". There's no resemblance to felt although it serves the same purpose.
seeyou is offline   Reply With Quote
Old 04-18-2011, 06:37 PM   #5
Rewards Points: 86
In your bid I’d say their the same, I still say “30lb felt“ just habit I guess.
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 12:26 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 09:44 PM
Window Flashing with Felt Siding user284 Remodeling 1 09-12-2010 11:32 PM
Felt for Reinke Alum Shakes SCDome Roofing/Siding 1 09-26-2009 02:53 PM
How do I attach the 15# roofing felt to the subfloor? rncopper Flooring 8 06-23-2008 10:17 PM
