30# Felt Paper For Ply? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-11-2010, 11:52 AM   #1
30# felt paper for ply?
Hey folks,
I know this is probably a stupid question, but I have a bunch of 30# felt paper left over from an old project. can I use this as a "ply" for a built up roof?
Thanks.
J
jlberkeley is offline   Reply With Quote
Old 09-11-2010, 06:27 PM   #2
Doing This Way Too Long
Rewards Points: 532
Well, you can do anything you want but felt and glass-ply are two totally different animals.
OldNBroken is offline   Reply With Quote
Old 09-14-2010, 12:12 AM   #3
Rewards Points: 968
is felt usually used as a base sheet?
federer is offline   Reply With Quote
Old 09-14-2010, 06:28 AM   #4
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I've seen it done, but never ever read a specification by a manufacturer or trade association saying you should do it.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 09-14-2010, 06:30 AM   #5
Grumpy's Avatar
Rewards Points: 552
Wait a minute... Hot tar do it yourself? Seriously reconsider that thought process, there are better DIY options for low slope roofing.
Old 09-14-2010, 02:43 PM   #6
Rewards Points: 968
thanks grumpy-no i am just trying to figure out whats usually used as the base sheet. i&w shield??
Rosin paper or 15# felt? Duane 70 Flooring 23 12-04-2009 07:13 PM
Felt Paper and the Sun. Valley problems hartkem Roofing/Siding 1 07-22-2009 03:57 PM
RoofGaurd vs Felt paper GerryinBelleRiv Roofing/Siding 5 06-30-2009 07:36 AM
Does felt paper allow a house to breathe? bluefitness Building & Construction 2 02-08-2009 08:42 AM
Is felt paper a sufficient vapor barrier for hardwood floor? jaj808 Flooring 15 03-27-2008 10:57 PM
