09-07-2012, 08:57 PM
#1
3 layers doesn't meet code???
Hey all, I just put a 3rd layer of composite roofing on my ranch house with a 4/12 roof in May. I'm selling the house and had a home inspection this week. He told the buyer that code is 2 layers and now I may have to tear off my new roof and start over. I'm in Portland or and I've been looking online to find this part of the code and can't come up with anything. Can someone help me out here. I did find on a "do I need a permit flyer" where it said you don't need a permit to reroof and a note that said 3 layers max. The inspector told my agent the code changed in 2002. Thanks for any input. Id rather not start over but will if I'm in the wrong.
09-08-2012, 01:10 AM
#3
Residential Designer
This is from your state code.
Just as Gary said.
Andy.
Residential Drafter/Designer
Reason: Took out picture of code, may violate a copywrite.
09-08-2012, 01:14 PM
#4
Average Joe/ex-Navy IC3
I would be calling the HI to the "table" and have them point out where it specifically states that you cannot have max 3 layers.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
09-08-2012, 01:42 PM
#5
If I were a buyer, I'd be looking for a substantial discount from the price of the home if the home has 3 layers.
09-08-2012, 01:50 PM
#6
Me to.
Now it's going to cost three times as much to remove them. Far more to dump them if you have tipping fees.
And far less likly to look flat, or stay stuck down or in place. Can also cause the roof to sag.
09-08-2012, 08:18 PM
#7
Pro Slate Roofer
Code or not, 3 layers is too many. That's over 700 pounds of dead load per sq.
Frank
09-09-2012, 11:36 AM
#8
Roofing Contractor
Ya 3 layers on a 4/12 is just asking for trouble. Do you get snow in your area???
We've done many hundreds of 4/12's and never taken off 3 layers, done a lot of 2 layer tear offs but never 3 on a low slope roof...
09-09-2012, 12:20 PM
#9
JOATMON
Playing dumb here (I'm good at it)....but are you sure it's 3 layers?
I thought I had 3 layers on my house when I bought it.....I was looking at the edge of the roof and counting that way....In reality, I had two....I was counting the starter strip....
In your case, if you had 3 layers....you would have 4 shingle layers on your edge....starter strip and 3 layers of shingles.
Next question....did you do the roof yourself or pay someone to do it? If you did it yourself....well....you know the answer already....if you payed someone to do it and they did not point out the issue.....well....I think I would be having a talk with them.....you somewhat expect a contractor to 'know those things'....
On a personal note....in 15 years when it comes time to do my roof again....I'll tear it all off....yea, may not be necessary....but looks a whole lot better....and it's a good time to repair any items that need attention.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
The Following User Says Thank You to ddawg16 For This Useful Post:
09-10-2012, 12:31 PM
#10
Hey all, thanks for the feedback and code info.
Sure enough we are under a couple codes so I just emailed my city inspector for his opinion.
I can see your points about the excess weight and not sitting flat so this will be my last 3rd layer.
If the buyer asks I will tear it off and start fresh (not happily, but I will)
I did the work myself so no one else to blame and I think I can do a tearoff and reroof for about 2k so that would be better then loosing a buyer.
I should know the outcome in a few days and I'll post just for fun. Thanks again, 1
ps: without a doubt there are 3 layers.
Reason: forgot something
09-13-2012, 12:47 AM
#11
Moderator
FYI- the total span of your rafters would be reduced by about a foot to two feet, varies; depends on the rafter size, shingle weight (average 2# sq.ft. per layer- times rafter on-center-spacing for sq.ft.), consult the rafter tables for the extra (dead) loads; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Older house, you are probably over-spanned already, before the extra...
Gary
Clothes taking longer to dry?
09-19-2012, 11:20 PM
#12
Update:
So I talked to my local city inspector that had signed off on the other aspects of my remodel about my roof problem. He told me that 3 layers was fine according to the Oregon state code, he also suggested I tell the HI to "go pound sand". I do agree that 3 layers is a bad idea for a number of reasons but it looks like I'm ok for this time. I won't be putting a 3rd on in the future. On a side not my buyer backed out because of financing issues so we'll have to wait and see if the next Hi has anything to say about the roof. That's all for now, 1
The Following User Says Thank You to 1dumbquestion For This Useful Post:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
