-   -   3/12 pitch roof leak (http://www.diychatroom.com/f9/3-12-pitch-roof-leak-94009/)
Pat Mulhron 01-30-2011 02:58 PM
I recently had my shingles replaced with similar asphalt shingles. Since that I am having leaks at the valleys especially. I contacted the contractor and he said he installed the ice guard 4 ft up from the roof edge. Prior to replacement I had no or very little leaks. Is there a solution to my problem? I have read about the rubber membrane but not sure that will solve this problem.
Roofmaster417 01-30-2011 08:41 PM
I always have fear installing shingles on a low pitch like yours.When installing on a low pitch as yours I ALWAYS spend the extra money and put Ice and water on the entire roof.I have never had a call back utilizing this practice.Also depending on the manufacture restrictions for 3/12 application I lower the exposure.Exposure being the amount of the shingle exposed.For 3 tabs exposure being 5" I will lower to 4".For arch's exposure being 5-5/8" I lower to 4-5/8".Since your roof is already installed and a complete reroof is not realistic then a proper repair is now the issue.If its not leaking everywhere but the valleys then this is my remedy.Florida requires a technique for high velocity winds that I feel in your case would prove successful.1st)Remove the valley and install Ice/Water.2nd)Apply 1 coat of fibrated asphalt roofing cement.3rd)Install a 90lb Awa plan.4th)Seal each individual shingle to the valley.It maybe extreme to some but your problem lies with pooling and back up due to such a low slope in the valleys.
OldNBroken 01-30-2011 10:45 PM
Sounds like an installation issue with your shingles.
Don't keep focusing on ice/water shield as that is not your problem nor your solution.
Millions of roofs like yours have been installed without any issues long before ice/water was invented. It's not a magic bullet but rather an excuse for lazy roofing. Your contractor should be focusing on why his ROOF is leaking, not why his underlayment is.
handy man88 01-30-2011 10:56 PM
Have you crawled into your attic to pin point where the leak is coming from?
The leak could be coming from a penetration through the roof like a gas flue or vent stack.
Roofmaster417 01-31-2011 01:31 PM
I think he is aware that he has a jacked install and his roofer might be draggin him around.He is wanting a remedy.And yes a bullet might be the remedy for the roofer.:laughing::laughing::laughing:
True these are installed daily without problems.It does sound like the roofer is relying on the materials versus common logic and experience with roofing.:)
