2x6 T&G, Insulation, Plywood....ughhh...help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 08:39 PM   #1
2x6 T&G, insulation, plywood....ughhh...help!
I've never replaced a roof on 2x6 T&G...What's the best way to finish the roof? I've already replaced about 22- 2x6x16 T&G and I'm ready to cover...I'm getting a lot of different opinions...should I cover the decking with 15w felt paper then Insulation. Poly or iso?...what r-value, thickness? What kind of button caps should I use? I plan on going over top of the insulation with 1/2" Ply. Should I screw plywood down or nail it? Should I cover ply with felt? The decking is on beams 4' off center (cathedral cieling) T&G in South Eastern Virginia. Please tell me your opinion on how to do this. 3/12 Pitch. I also plan on using 3 tab 25 year to finish.
DIY2009 is offline   Reply With Quote
Old 09-10-2010, 08:46 PM   #2
Registered User
Rewards Points: 5,216
http://danperkinsroof.com/1108_JCL_Perkins_A.pdf
Gary
Old 09-10-2010, 09:49 PM   #3
Good link!It should answer all his questions.
johnk is offline   Reply With Quote
Old 09-11-2010, 11:53 AM   #4
Great Link!! It also addresses ventilation...thanks!...Seriously! I couldn't thank you enough!
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Old home insulation woes nowwhatnapster Building & Construction 15 11-03-2008 12:59 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
