2x4 Rafters/roofing Question... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-10-2011, 10:42 PM   #1
2x4 rafters/roofing question...
i helped a friend build his garage's roof, kinda of uncomfortable.
he says lowes told him he could use 2x4 for rafters with 1/2 inches plywood for asphalt shingles.
the rafters are 18 foot long without beams or trusses (garage 28x40).
he's already got the 2x4 up for rafters and it's ready for laying plywood tomorrow.
i told him plywood and asphalt shingles would be too heavy.
he could get his money back for the plywood and do tin roof setup instead.
he wanted the 2x4 anyway and is going to think overnight about tin roof or not.
he also mentioned that he'd like to renovate the garage to a house in the future and felt tin roof would not do.
help me out here guys.
thanks
powchutu is offline   Reply With Quote
Old 10-11-2011, 05:26 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Irregardless of the roof material, maximum allowable span for 2x4's is 10'.
Max span of 2x6's is 20'.
And the less slope there is, the sooner it will collapse.
The plywood alone is too heavy a load, by itself, by far.
tinner666 is offline   Reply With Quote
Old 10-11-2011, 06:17 AM   #3
kwikfishron's Avatar
Rewards Points: 430
he says lowes told him he could use 2x4 for rafters with 1/2 inches plywood for asphalt shingles the rafters are 18 foot long
WOW….. Lowes and/or your friend are wrong and by a long shot. For an 18’ rafter span you’re looking at 2x10 not 2x4 and even then I can’t say because we have no idea what the load requirements are for your area.
This is a recipe for disaster you need to STOP NOW. One of the reasons we have a permit process is to keep stupid **** like this from happening.
I’ve heard of some real bad advice coming from box stores before but this takes the cake.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
rossfingal (10-11-2011)
Old 10-11-2011, 07:04 AM   #4
Civil Engineer
Rewards Points: 4,704
We don't know where the OPS lives, could be in New Guinea for all I know. We don't know what Lowes actually said, all we have is a vague third hand statement attributed to his friend. And we don't know the building code, if there is one, in the area. So in short, we don't know what proper practice, code practice, or even reasonable practice would be in this specific case. If the OPS is uncomfortable helping out, he can point out the potential issues to the owner, and let the owner decide on the next step. Personally, I would be nervous standing on a 2x4 framed roof spanning 18 feet, I have seen roofs fail, very dangerous.
Also note that the OPS did not mention the spacing of the rafters, the pitch, the species and grade, or anything else that might be useful in determining allowable span.
As an aside, substituting tin roof for plywood is not going to improve the situation, as the plywood adds considerable strength to the rafters, whereas the tin does not.
Daniel Holzman is online now   Reply With Quote
Old 10-11-2011, 07:48 AM   #5
The best you (the OP) can do is to tell your friend that you have concerns, and suggest that they seek a professional opinion. If that doesn't work, then I would decline to continue helping with the project.
1910NE is offline   Reply With Quote
Old 10-11-2011, 08:25 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
Why such a step pitch? The wind may blow it over before the sheathing even goes on.
PoleCat is offline   Reply With Quote
Tags
2x4 rafters/roofing
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
