2layer #15 Vs 1layer #30 - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-11-2010, 02:40 PM   #1
Rewards Points: 284
2layer #15 vs 1layer #30
For low slope shingle roofs like mine, the city requires 2 layers of felt. My 3:12 does not actually require it, but I was planning on using 2 layers of #15.
A roofer suggested that 2 layers of #15 had no benefit over 1 layer of #30.
In that case I would use 2 layers of #30. What do you think?
tns1 is offline   Reply With Quote
Old 09-11-2010, 04:26 PM   #2
Go for it!Double up first row and then just go to the half-line the rest of the way.Then you definitely have sufficient underlay.
johnk is offline   Reply With Quote
Old 09-11-2010, 07:22 PM   #3
steveel's Avatar
Does 30# lay flatter than 15?
steveel is offline   Reply With Quote
Old 09-14-2010, 07:05 AM   #4
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I use 30# on all my sloped roofs. I do not use 15#. Minimum code sucks. However I don't see any added benefit of using 2 layers of 30#. Are you going to use ice shield at your gutter lines and valley areas? (I don't think you don't get snow in San Diego, but the ice shield also helps against water infiltration, especially in the valleys.)
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
