$2000 For A Few Pipe Stands For Roof??? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-21-2012, 05:21 PM   #1
Rewards Points: 1,062
$2000 for a few pipe stands for roof???
People,
getting a quote for a new roof- flat roof, 20x20 patio, with wood deck on top of the roof. Currently, the deck 4x4 posts protrude THROUGH the roof, and attach to 2x8's below. leakage is very bad during rains at those spots. Guess rain seps through the sides of the posts, and simply drips down through the roof.
So, roofer proposed to tear down the whole deck, cut off the 4x4 posts, and put in these "pipe stands/brackets, which will be the holding the new 4x4 posts. I guess the membrane will be sealed around the steel brackets/pipe stands. He said these 15 stands must be custom made, and will cost a whopping $2100. Geez. How is this possible? Done these come stock at say, roofers supply? Am I the first guy that needs a roof with a deck on top with no posts going through the roofing membrane?
Thanks!!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 03-21-2012, 05:22 PM   #2
Oh, thats just for the stands! Roof is another $$$$$$$$$$.
Old 03-21-2012, 05:54 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Don't know if these apply to your situation, or will help (very cost efficient): http://bisondecksupports.com/deckSupports.php
http://bisondecksupports.com/index.php
- Build Well -
The Following User Says Thank You to AtlanticWBConst. For This Useful Post:
noquacks (03-21-2012)
Old 03-21-2012, 06:38 PM   #4
Rewards Points: 252
I'm not sure what your local code says about anchoring the deck down or not, but I would look into it to see if you can just sit the deck on top of the roof.
As for cost, it depends how many supports we are talking about. I can't imagine what he plans on making... If it were me I would buy a pre made support post flashing like so http://www.thalermetal.com/architecturalroofsuppor.html or just build a sleepers
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
Old 03-21-2012, 06:44 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
sounds like a pitch pocket of some sort
Tom Struble is offline   Reply With Quote
Old 03-21-2012, 07:00 PM   #6
Thnaks, guys. Links are interesting. But, good point on looking at local codes if deck has to be anchored. I could call a local supply house- maybe theyd know, or better yet, the city hall itself.
Old 03-21-2012, 07:30 PM   #7
RFN-4A-LVN
Roofmaster417's Avatar
I have always informed my customers that before they hire a contractor for anything exterior to always contact your local building department for restrictions and compliance regulations.
Educating yourself can greatly reduce the chances of being scammed or an owner of a crap exterior installation.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
Old 03-21-2012, 09:08 PM   #8
robertcdf's Avatar
$100 bucks a bracket with a 40% markup... Kind of depends upon how the bracket is made, I've paid near $100 for customized brackets before.
robertcdf is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-25-2012 11:58 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
Furnace Venting Requirments jamiedolan HVAC 9 11-18-2008 05:40 PM
