Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-10-2011, 03:46 AM   #1
2 years, 2 roofs and 3 ridges later: still no joy.
I appreciate the feedback. Have to "go".
Chaucer13 is offline   Reply With Quote
Old 12-10-2011, 03:50 AM   #2
paper hanger and painter
chrisn's Avatar
WOW,I am speechless.
Old 12-10-2011, 10:37 AM   #3
Exterior Construction
Windows on Wash's Avatar
More pictures would be helpful in this application.
Regardless of the current state, you have an opportunity to get it don right this time.
Given the climate in your region and the relatively small insulation depth in those cathedral sections, I would suggest that try to do some reading on your options.
You might be well served to contract with a building efficiency professional as well so that he can help coordinate your efforts.
BSC Roof Design
I am sorry you are getting such bad contractors out there.
Old 12-10-2011, 10:46 AM   #4
Insulate and install metal easy fix on that
ROBERT F1 is offline   Reply With Quote
Old 12-10-2011, 10:51 AM   #5
Over 30 years in the business and I've never seen a roof framed like that.
No ridge pole, rafters run in the wrong direction, there going to sag if run that way and there's no way to run a flat ridge vent and nothing to even attach it to.
If it was my job I'd walk away unless they let me redo the whole roof from scratch.
Old 12-10-2011, 10:58 AM   #6
Yea it was a first for me but i doubt thier going to reframe the roof line and cielings might as well build another house.
Old 12-10-2011, 12:07 PM   #7
Doing This Way Too Long
I guess that's a first for a lot of us. 30 years of looking inside roofs it's a first for me too.
So, that aside, what are you asking for here? Watertight integrity or aesthetics? I understand the first roofer did a terrible job, hence the re-roof. Hopefully they fixed all those issues and now you are left with the aesthetic problem. Honestly, This is one job where I'm going to have to say you can only do so much to make that look good. The waviness is due to the framing underneath and it's nothing a roofer can fix. As far as ventilation, not really a big issue there either.
As stated earlier, unless you remove the roofdeck, true up the walls and re-frame your roof, you can't expect too much.
OldNBroken is offline   Reply With Quote
Old 12-10-2011, 02:11 PM   #8
Old 12-10-2011, 02:27 PM   #9
Wow! I must say I really like the interior of that house. If your immediate concern is the ridge leaking and you plan on re-doing it in the spring I would suggest having them just roll out some heavy ice/water shield or synthetic and securing it the length of the ridgeline until spring. There will be some framing involved then to give you a nice straight ridgeline but it can be done.
Old 12-10-2011, 02:30 PM   #10
RFN-4A-LVN
Roofmaster417's Avatar
Wow.,.,This might be the first time 417 has only one word to say..,.,.,
Roofmaster417 is offline   Reply With Quote
GAF stormguard for low pitch roofs Dave K Roofing 2 05-11-2011 06:39 AM
Best Mod Bit for Flat Roofs Hockey88 Roofing 10 11-28-2010 11:30 AM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing 3 11-06-2009 10:07 AM
proper way to install ice - water shield on roofs rjh Roofing 1 06-01-2009 05:38 PM
Hip roofs and hurricanes cittyguy Roofing 3 05-23-2009 08:38 PM
