2 Roof Questions ! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-14-2008, 03:07 PM   #1
2 Roof questions !
Hello all, I am roofing a new shop building that has 1/2" CDX ply as a base. Are staples or nails better? What lenght do you advise? I will buy an air gun for this project as well as an overlay project of my house roof in the spring. What gun should I buy? Keep in mind I will sell the gun after the projects are complete so re-sale is an issue. Thanks for any help !
A-NailBender is offline   Reply With Quote
Old 11-14-2008, 06:11 PM   #2
Residential Roofer
Slyfox's Avatar
1 1/4" nails works for most 25 thru 40 yr shingles, some 50 yr/ life times require 1 1/2".
Bostitch nailer.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 11-14-2008, 07:33 PM   #3
Hitachi or Bostich will do you very well.
they are available at the ABC Roofing Supply stores.
Also, check with your local pawn shop for an inexpensive alternative.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-14-2008, 10:06 PM   #4
I like the Hitachi nailers, very little down time with them
Also I recommend using hot dipped galvanized nails over the electro galvanized version. They will last longer.
Dale (DC Roofing Inc)
Dale Chomechko is offline   Reply With Quote
Old 11-15-2008, 11:30 AM   #5
So the 1 1/4 " would be sticking through about 1/2" on the inside of the new building project correct and thats normal? And you dont like staples vs nails right? Thanks.
Old 11-15-2008, 11:32 AM   #6
What model of Hatachi do you like,thanks.
Old 11-15-2008, 11:52 AM   #7
Yes the nails do extend thrugh the sheeting, but if you have open soffits & 3/4" T & G decking we recommend 7/8 hand nails around the perimeter
You want the shank of the nail holding the shingle, not the point.
I do not like staples in plywood or in roofing materials.
They seem to losen up in plywood or if the roof deck was wet tend to rust(especially in my climate)
In shingles a good wind when it pulls on the staple & tends to cut into it(the shingle) & they tear out. Everywhere I have seen them I have also seen a lot of torn shingles
Most of the ones I have seen were a while ago as nobody uses them any more
NV45AE 1-3/4" Roofing Coil Nailer
Old 11-15-2008, 12:42 PM   #8
Thank you very much for the detailed response !
Old 11-15-2008, 09:59 PM   #9
Not only normal, but spec.
Read the fastener penetration requirements from the shingle manufacturers to find out for yourself.
Ed
Old 11-23-2008, 11:50 AM   #10
Commercial Roofing
AaronB's Avatar
Porter cable nailers are trouble -free and inexpensive.
Resale on the gun is a non-issue. Keep it for your reroof.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 11-24-2008, 06:45 AM   #11
the roofing god's Avatar
Send a message via MSN to the roofing god
Bostitch is the best nailgun on the market-period
staples are nowhere near as good as nails
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 11-24-2008, 01:32 PM   #12
I staple all my plywood,IMO staples hold better than nails.Replace a sheet thats nailed and one thats stapled.Say no more!
johnk is offline   Reply With Quote
Old 11-24-2008, 01:52 PM   #13
That does not jive with the actual test results, unless you are placing the staples at a 2" OC pattern.
Ed
Old 11-24-2008, 02:17 PM   #14
Ed
I use 6" OC.Thats why I said IMO.It also matters how your staples are placed vertically or horizontally.Whats your typical nail pattern?Also what size of staples were tested?Who asked you anyway,Ed?J/K
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 11:00 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
