2:12 low slope roof + shingles
Can anyone point me to a Code (National or State) that allows shingles to be placed on this type of roof - and do you do them in your particular area? If so, what extra precautions would you recommend apart from Ice Shield throughout. And if you do not do them, what is your reasoning?
They (ie 2:12 and shingles) seem to be according to code in Florida, but is there a particular requirement in Florida that would be overriden in, say, the Northeast or in Michigan where snow and ice are more common. Just looking for insight from those who are in the Northern part of the country who run into this question...in my case I have a 30yr old, non-shingled 2:12, very little ventilation and trying to get ready for the inevitable :huh: |
You can read the Steep Slope Manual by the NRCA Online for free by just registering here:
http://www.nrca.net/rp/technical/manual/default.aspx Also, check out: http://www.asphaltroofing.org/ for the ARMA publications. Ed |
It's not recommended by any shingle manufacturer for obvious reasons that you seem to already know. That being said, there have been occasions we have done them and haven't had any problems.
Aside from the ice/water, I highly recommend installing them the hottest, driest time of the year to ensure maximum sealing. Make sure your exposure is tight and proper, and make sure your endlaps are extreme. For ventilation use shinglevent II as others tend to allow wind-driven rain and snow to pass through on occasion, especially at that low a slope. You might also want to consider an SA system (certainteed flintlastic 3-ply is my preference) as your roof is what they were designed for. Good luck and hope this helps. |
not a chance would I shingle 2:12. especially not when I know ice will be sitting on it.
Can you repitch it? If not, use an alternate material. Flintlastic (Certainteed), or a BUR, or a single-ply. |
Thanks guys...can you not put down an Ice&Water shield all over i.e complete coverage, then shingle on top of that?
I have done this in the past here in the northeast and had no problems so far. but only if there was no other option . I have installed Ice & water Over the whole deck then installed shingle mate. And then installed the shingles with a 4" exposure. like I said I would look for other alternatives before going this route. no guaranties from me or the manufacture.
BuletBob: why would you install ShingleMate and Ice&Water shield? can't you substitue I&W for the ShingleMate, and shingle over either one? I thought ShingleMate was a premium felt. :huh:
the shingle-mate will help wick any moisture that could form under the shingles
Like OnB has said ... regardless of what your underlayment is, or how many underlayments you put down, you'll end up with thousands of holes thru all the layers of your underlayment(s) with a 2/12 pitch (and that's where the roof isn't deflected).
Anybody can call themselves a carpenter or craftsmen but a good carpenter or craftsmen will find a solution to the problem. Which in this case with four generations of experience I truly feel I achieved. |
| All times are GMT -4. The time now is 10:45 AM. |
