1'X20' Flat Roof Repair - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 03:54 PM   #1
hohadcr's Avatar
Rewards Points: 346
1'X20' flat roof repair
Thank you for reading my question.
I have a small area of roof (first floor addtion) that measures around 1.5ftX20ft. The roof has a small slope leading water to the gutter.
The material looks like normal black tar, no signs of shingle or paper. There are a lot of areas on this small roof is bubling up and cracking.
What can I do to repair this small piece of roof? Some one suggested throwing some more tar on top. Does that work?
Thank you all in advance.
hohadcr is offline   Reply With Quote
Old 08-25-2009, 07:13 PM   #2
Commercial Roofing
AaronB's Avatar
Removal and replacement of a roof that size should be relatively inexpensive.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 08-25-2009, 11:17 PM   #3
1.5 feet or 15 feet?
No, throwing tar will at best, be a very very temporary band-aide.
If it is one of those DIY emulsions that are extremely luquidy, you will wind up paying double or triple to have your roof done correctly when it starts to leak.....and it will.
As soon as the product starts to age and harden, without a reinforcement scrip to hold the composition together, whatever it is attached to, ie; the roof surface, will bare the brunt of the expansion and contraction forces which will wind up spliting the underlying roof membrane material.
Ed
Ed the Roofer is offline   Reply With Quote
Flat repair roof of condo building Stillwerkin Roofing/Siding 7 03-02-2009 06:34 PM
what type of flat roof in coast home? starrider Roofing/Siding 7 02-19-2009 09:48 PM
Flat roof venting question vendejp Roofing/Siding 8 07-17-2008 03:45 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
