1st Rain = Discovered Roof Drainage Problem - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-04-2008, 02:29 PM   #1
Rewards Points: 77
1st rain = discovered roof drainage problem
We had our 1st rain this past weekend. And, we discovered that the enclosed patio roof has a(or some) drainage problem(s).
I'm a beginner so please forgive my poor choice of terms and ignorance. I'll take a picture and post it, but here's a verbal description:
- The metal roof has a built-in drain/gutter along the 2 edges.
- The metal roof has 2 downspouts located at the outer corner and 1/2-way along (in the middle of) the lower edge.
- The water flowed out the inner corner, around the corner "cap" despite some older looking caulking on the outside of the cap, and in a line of drips between that corner and the middle downspout.
The leakage soaked the door, its frame and the inside wood panels radiating away from the doorway.
How do we solve/fix?
1st rain = discovered roof drainage problem-patio_roof_drainage-003-75-.jpg   1st rain = discovered roof drainage problem-patio_roof_drainage-004-75-.jpg   1st rain = discovered roof drainage problem-patio_roof_drainage-005-75-.jpg
1655graff is offline   Reply With Quote
Old 11-05-2008, 06:06 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
You will probably need a pro experienced with these. So many parts are integeral with each other, there is seldom a simple fix. Often, the leak gets built into the unit and some disassembly is needed.
tinner666 is offline   Reply With Quote
Old 11-06-2008, 10:09 AM   #3
Rewards Points: 77
Before we do that, there must be some helps/fixes we can DIY, eh?
What if we reframed the doorway, very slightly elevating that section of the roofline?
What if we just recaulk the corner cap? And with which caulk? Do you use the same caulk on the outside as on the inside of the gutter/corner?
What if we add a downspout for the corner by the door?
What if we add a deflecting "roof" for the doorway?
What if we shellac prime and paint the doorway's wood?
What if we... (fill in with your recommendations)
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
Ripping roof off, rain protection? wease Remodeling 2 12-23-2006 09:08 AM
roof not on yet and a whole lotta rain THEBIGPUNN Building & Construction 10 11-21-2005 06:15 PM
garage roof problem ERIK2173 Roofing/Siding 3 11-03-2005 07:44 AM
