1930's Low Pitch Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-15-2012, 08:33 PM   #16
AGWhitehouse's Avatar
You should have a ridge that connects the two 30 degree roofs at their mid-span. Taper out to the roof edges. If the price is right you can get rigid polyiso panels at 1/4" per foot slope to get it done. Cover with a low-slope roofing material of your choice.
If you want all shingles, run the ridge beam from the lowest of the two 30 degree ridges to the other at the heigh to the shingled roof ridge beam. Custom cut the birds mouth seats for the infill joist framing. sheath and shingle.
The red is showing the new roof slope that needs to be added. The black is the existing shingle roofs. The red will tie into the black ridges if you want to shingle the surface. It can be lower, but you'll have to use a membrane.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
The Following 2 Users Say Thank You to AGWhitehouse For This Useful Post:
audiohere (07-16-2012), Windows on Wash (07-15-2012)
Insulating/Vapor barrier/Venting a 2/12 pitch Shed Roof with Cathedral Ceilings cmlarsen Insulation 6 12-21-2011 10:50 PM
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 09:43 AM
Adjusting LVL beam to pitch of roof tobicol7 Building & Construction 1 06-05-2010 02:22 AM
10/12 Roof Pitch jonathan03 Roofing/Siding 5 04-03-2010 10:24 AM
2.25 pitch roof...15 or 30 lb felt? my5sons Roofing/Siding 13 12-08-2009 06:08 AM
