1928 Metal Roof Rusting - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2006, 02:14 PM   #1
1928 metal roof rusting
I am contemplating purchasing a new (old) home built in 1928. It has a terra cotta style metal roof that is rusting and badly chipping. It does not look like the roof is rusted through and there are no signs of water leakage. Given the age and rusting is this a seriously bad problem? How difficult (expensive?) is it to repaint a metal roof?
Thank you for any advice you may offer.
basilbiko is offline   Reply With Quote
Old 07-15-2006, 07:20 AM   #2
Rewards Points: 14
I, for one, don't think any non-factory applied paint is worth a squat on metal roofs. They rarely withstand more than a year or two of weathering, they look like crap from the get-go (especially if not sprayed on) and even nullify the historical character, if that is the goal of painting the roof vs. replacing the roof. That said, surface prep, as always in painting, is the key to how good the finish will look and how long it will last. The two-part epoxy paints, available only from industrial/professional supply houses, look the best and provide a decent amount of protection. In my experience, it is harder to properly apply the two-part epoxy paint than it is to simply install new roofing panels.
A key question is, what's your motivation for painting the roof rather than replacing it?
allpraisebob is offline   Reply With Quote
Old 07-15-2006, 01:01 PM   #3
Commercial Roofing
AaronB's Avatar
Basilbiko, where are you located?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 07-15-2006, 01:02 PM   #4
Commercial Roofing
AaronB's Avatar
Where areyou located?
Old 07-19-2006, 12:53 PM   #5
macomb Il
Old 07-19-2006, 12:57 PM   #6
Allpraisbob,
Unfortunately, the roof style is a terra cotta style, which is no longer manufactured. My goal is to presserve the integrity of the roof and style of the house overall. Thanks for your insight.
Standing seam metal or membrane for 1.4/12 pitch shed roof? regulajo Roofing/Siding 21 06-18-2007 09:58 AM
Metal roof looks right for me but how do I install? Tubenoob Roofing/Siding 8 04-15-2007 01:51 PM
Black Metal Roof??? Goat66 Roofing/Siding 2 01-31-2007 11:58 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 10:40 AM
