15 Lb Or 30 Lb Underlayment? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-20-2005, 03:57 PM   #1
15 lb or 30 lb underlayment?
I was told the roof pitch on my house was a 12 to 4 (?) and it is just fine to use a 15# underlayment vs the heavier 30#. Is this ok or BS? I'm wanting the new shingle roof I'm gonna have installed to last as long as possible and wouldn't mind spending a little more for the better stuff. What do ya think? TIA
Hossman is offline   Reply With Quote
Old 08-20-2005, 05:06 PM   #2
GMW
15# is fine. 30# is usually used on steeper roofs as it is thicker and can stand up to being walked on. Also you should use an ice and water barrier along the front.
GMW is offline   Reply With Quote
Old 08-22-2005, 07:13 PM   #3
Grumpy's Avatar
Rewards Points: 524
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I don't use anything other than 30# because I do not trust 15. I only use 15 when it's new construction and the builder refuses to pay for 30, and I don't have much work.
Use Ice and water shield in the critical areas regardless of the felt weight you choose. Those areas are gutter lines, valleys, and penetrations like chimneys skylights pipes etc...
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 08-22-2005, 09:15 PM   #4
Thanks, guys. I think I'm gonna stay with the 30# stuff for piece of mind. Thanks for the tip on the ice/water shield.
Old 09-06-2005, 06:59 PM   #5
#15 or #30
Go with #30 i'ts heaver and is the same price, ck home depot.
mjswindows is offline   Reply With Quote
Old 09-06-2005, 10:37 PM   #6
jproffer's Avatar
Rewards Points: 706
That's true....sorta. The 30# and the 15# are the same price usually, but the 15# covers 4 sq. per roll, and the 30# covers 2, so per sq, the 30# is double the price of the 15#, as you would expect.
jproffer is online now   Reply With Quote
Old 09-13-2005, 10:47 PM   #7
Commercial Roofing
AaronB's Avatar
I do not think it makes a difference unless youre leaving the roof dried in for a long period of time. The felt does absolutely nothing as far as waterproofing after you nail the shingle roof assembly on top of it....it is full of a gajillion holes and if water gets into the shingle assembly, youre in bigger trouble than your dry in material/separator sheet.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Trafficmaster Allure - Underlayment? HuskySkull Flooring 47 06-11-2014 04:04 PM
laminate floor underlayment installation? KUIPORNG Flooring 1 03-08-2007 05:52 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
Underlayment for laminate dm62 Flooring 3 04-02-2005 10:56 AM
