12" Fascia - too large?
3K views 6 replies 4 participants last post by  Tom Struble
I am looking to use 12" thick steel SIPs for my roof. This would in turn make my fascia area 12" in height.
Do you think a 12" fascia would be aesthetically too large? I will utilize gutters so this should help break up the area.
Flat roof, eh? If there was any slope to it, the cut off end, like a rafter, would increase in size.
Honestly thoough, I'm not familiar with the product. But, like the rafter, the bottom could then be cut on it's heel to decrease it's size, or the soffit could be built out in a way to minimize it's size/shape. There are ways to do this.
The 12" thick steel SIPs could stop nearly flush with the outer wall, then a soffit could be attached by ledger, or band, and smaller rafters to complete the roof line so the fascia can be 'framed' to any desired size.
#5 ·
Thanks for the advice.
You don't happen to have any pics available?
The thing I like about steel SIPs is that it is a very strong structural panel and one does not have to have an attic. The 12" panel is R-50 and once it is placed on top of the rafter beam and the exterior wall, it is screwed down at 8" o.c. and you are basically done. You still have to put down a metal standing seam roof on top of it but otherwise no need for trusses or framing.
#6 ·
Jack,
I don't have any pics, but if you google it, I'm sure you'll find some. The ones I saw were just varying widths of cedar applied one on top of the next, starting with a 1 x 12, then maybe a 1 x 8, then 1 x 4. The wood was 4/4 thick though, not 3/4". Looked better being a little beefier.
Mike Hawkins:)
