12/12 Pitch Rafter - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-12-2011, 03:13 PM   #1
12/12 pitch rafter
My shed is 20/20, how do I build a 12/12 pitch rafter that will work on my walls?
LarryBiggerstaF is offline   Reply With Quote
Old 12-12-2011, 04:31 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Your shed is 20/20 what? Does that mean it can see good?
titanoman is offline   Reply With Quote
Old 12-12-2011, 04:33 PM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Lay it out on the floor of your shed
tcleve4911 is offline   Reply With Quote
Old 12-12-2011, 04:34 PM   #4
Disabled wood vet
titanoman's Avatar
No. Do the math.
Old 12-12-2011, 04:39 PM   #5
Rewards Points: 14,312
http://www.howcast.com/videos/179909...-Rafter-Layout
Old 12-12-2011, 04:39 PM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Originally Posted by titanoman View Post
No. Do the math.
Do both...........
Old 12-12-2011, 04:41 PM   #7
Disabled wood vet
titanoman's Avatar
Do both...........
No reason to waste time chalking lines on a floor.
Old 12-12-2011, 04:44 PM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Okay then,
Please do a tutorial about 'how to lay out a common rafter on a 20' wide shed with a 12/12 pitch.
Thank you
Old 12-12-2011, 04:46 PM   #9
Disabled wood vet
titanoman's Avatar
If you're saying your shed is 20' wide, you rafters are 172.04", minus 1/2 the width of the ridge, from long point to short point, measured across the top of the rafter. The long point being the ridge, the short point squared (45) across the board to the seat cut on the wall. Got it? (its called the pothagerium theory-a+b=c)
Old 12-12-2011, 04:50 PM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
op's gone................
Old 12-12-2011, 04:50 PM   #11
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
If you're saying your shed is 20' wide, you rafters are 172.04", minus 1/2 the width of the ridge, from long point to short point, measures across the top of the rafter. The long point being the ridge, the short point squared (45) across the board to the seat cut on the wall. Got it?
Unless you want some overhang. Then, you need to add a bit more depending on how you want the overhang. And to see how each lenght would look, you may then have to lay it out on the floor.
tinner666 is offline   Reply With Quote
Old 12-12-2011, 04:51 PM   #12
Disabled wood vet
titanoman's Avatar
Of course.
The Following User Says Thank You to titanoman For This Useful Post:
tinner666 (12-12-2011)
Old 12-12-2011, 06:06 PM   #13
Doing This Way Too Long
Rewards Points: 532
Actually it's pythagorean.
And, no, I have nothing useful to add. I'm just enjoying your exchanges. The spell-check was just an excuse to post...
Carry On
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
seeyou (12-12-2011)
Old 12-12-2011, 06:10 PM   #14
Disabled wood vet
titanoman's Avatar
Thank-you. I figured I spelled it wrong. Heck I can barely say it. It's some mathematicians name I think.
Rafter Calculations - help me understand, please. wombosi Building & Construction 25 09-11-2011 10:48 AM
Rafter tie adjustment albanello Building & Construction 10 11-20-2010 10:26 PM
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 08:43 AM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 07:55 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 10:31 AM
