10/12 Roof Pitch - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2010, 09:53 AM   #1
10/12 Roof Pitch
Is a 10/12 Roof pitch walkable? I want to put on shingles in a small area of the roof but I'm wondering if I can just support myself by sitting down or if I need a ladder resting against a 2x4 nailed to the roof. What is generally the best way to be supported on a roof like this? I'm comfortable laying shingles, just not sure if this pitch is too steep to walk on or other means. Is a cherry picker needed?
jonathan03 is offline   Reply With Quote
Old 04-02-2010, 12:22 PM   #2
Barely. Mine is 10/12. I can walk in valleys and on peaks, but do not dare attempting to walk on other areas for fear of sliding off.
I would not attempt to install a roof without additional support. I believe the common way of dealing with this is roof jacks.
oberkc is offline   Reply With Quote
Old 04-02-2010, 02:22 PM   #3
jlhaslip's Avatar
Rewards Points: 1,564
roof jacks, planks, and a fall protection/positioning harness/rope system.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 04-02-2010, 10:06 PM   #4
Rewards Points: 24
10/12 is pushing it. I wouldn't attempt to roof that without roof jacks and a harness.
Was a roofer for 6 years
KyleB is offline   Reply With Quote
Old 04-02-2010, 11:40 PM   #5
Commercial Roofing
AaronB's Avatar
Too steep to safely walk. Def use some form of fall protection and support while working.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-03-2010, 09:24 AM   #6
if you are going to fall wear proper rope and harness with deceleration attatchment
The older I get the better I was
Changing a roof pitch dcsobob Building & Construction 0 12-29-2009 10:28 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
